주요 콘텐츠로 건너뛰기
Replacing BMW Navigation Computer CD or DVD Drive E39 E38 X5 E46
필요한 것
동영상 개요
A video about replacing Navigation in BMW E39 http://www.youtube.com/watch?v=rmcAAYLmL....
  1. Replacing BMW Navigation Computer CD or DVD Drive  E39 E38 X5 E46, BMW Navigation Computer CD or DVD Drive  E39 E38 X5 E46: 1 단계, 이미지 1/1
    • Replacing a faulty Navigation computer CD or DVD drive or Upgrading an older navigation CD drive to the BMW DVD Navigation Drive is a plug and play upgrade in all model years
    • BMW MKIV DVD Navigation drives can be purchased from online retailers. Do a google search for "BMW MKIV Navigation Computer" for available options
  2. Replacing BMW Navigation Computer CD or DVD Drive  E39 E38 X5 E46: 2 단계, 이미지 1/3 Replacing BMW Navigation Computer CD or DVD Drive  E39 E38 X5 E46: 2 단계, 이미지 2/3 Replacing BMW Navigation Computer CD or DVD Drive  E39 E38 X5 E46: 2 단계, 이미지 3/3
    • Different BMW models require a slightly different process to remove the navigation computer however all are generally the same. The following photos show removing the navigation computer in a BMW E38 7 Series
    • In the back of the car locate the navigation computer drive and insert 4 pieces of a cutup coat hanger or a "Radio Removal Tool" into the holes of the drive
    • Once the tools are in the holes you can grasp the navigation drive faceplate and slide it out
    • Photo shows closeup of where the tools release the locking mechanism
  3. Replacing BMW Navigation Computer CD or DVD Drive  E39 E38 X5 E46: 3 단계, 이미지 1/3 Replacing BMW Navigation Computer CD or DVD Drive  E39 E38 X5 E46: 3 단계, 이미지 2/3 Replacing BMW Navigation Computer CD or DVD Drive  E39 E38 X5 E46: 3 단계, 이미지 3/3
    • Remove the plastic trunk liner screws to gain access to the wiring behind the navigation computer
    • Slide out navigation dive and disconnect the blue and magenta plus
  4. Replacing BMW Navigation Computer CD or DVD Drive  E39 E38 X5 E46: 4 단계, 이미지 1/2 Replacing BMW Navigation Computer CD or DVD Drive  E39 E38 X5 E46: 4 단계, 이미지 2/2
    • If your BMW is a 2000 Model Year or older, you will need to disconnect the separate GPS receiver located to the left of the navigation drive in the E38 or behind the amplifier bracket in the BMW E39
    • Once disconnected, connect the antennna wire to the back of the new navigation drive and remove the old separate GPS module as it will no longer be required
  5. Replacing BMW Navigation Computer CD or DVD Drive  E39 E38 X5 E46: 5 단계, 이미지 1/1
    • Connect the Navigation Drive and slide back in place. Then leave car off and outside for 20 minutes in order for the unit to recalibrate to the current location
    • For more information do a google search for "BMW MKIV Navigation Computer"
결론
다른 6명이 해당 안내서를 완성하였습니다.
Martin Bishop
회원 가입일: 01/26/12
4,373 평판
안내서 16개 작성하였습니다
댓글 3개
Thanks buddy for your instructions
''“Kayhan Audio“''
kayhan audio - 답글
Whether you're searching for a ride to the air terminal, or a limo to get you and take you to a gathering in the city, Birds Wing is your finished ground transportation answer for and from the air terminal. Our drivers are expertly prepared and will take extraordinary consideration of you and your family or business partners. Boston Car Service to Airport
Perla Weber - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 58
전체 시간: 28,363
