주요 콘텐츠로 건너뛰기
Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle
필요한 것
  1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle, Cog and lockring: 1 단계, 이미지 1/1
    • Remove the 9.5mm bolts on the rear wheel with an adjustable wrench. There is a bolt on each side of the wheel.
  2. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 2 단계, 이미지 1/3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 2 단계, 이미지 2/3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 2 단계, 이미지 3/3
    • Loosen the 4mm by 50.8mm chain tension screw with a hex key. There is a screw on each side of the wheel.
  3. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 3 단계, 이미지 1/2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 3 단계, 이미지 2/2
    • Remove the chain from the rear wheel cog. Remove the rear wheel from the frame of the bike.
  4. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 4 단계, 이미지 1/2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 4 단계, 이미지 2/2
    • Remove the lockring on the back tire using a lockring wrench. To loosen the lockring twist the wrench clockwise.
  5. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 5 단계, 이미지 1/2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 5 단계, 이미지 2/2
    • Loosen the cog using a chain whip and adjustable pliers. Rap the chain whip around the cog. Push the chain whip handle down so that the cog twists counterclockwise.
    • It will take a lot of force to loosen the cog.
  6. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 6 단계, 이미지 1/2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 6 단계, 이미지 2/2
    • Remove the cog the rest of the way with your hand. Replace with a new cog.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Loboda
회원 가입일: 10/07/19
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 53
전체 시간: 3,920
