주요 콘텐츠로 건너뛰기
Replacing Creative Zen X-Fi Battery
필요한 것
  1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: 1 단계, 이미지 1/3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: 1 단계, 이미지 2/3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: 1 단계, 이미지 3/3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: 2 단계, 이미지 1/1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: 3 단계, 이미지 1/1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Battery, Button Input Chip: 4 단계, 이미지 1/1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: 5 단계, 이미지 1/1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: 6 단계, 이미지 1/1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: 7 단계, 이미지 1/1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Replacing Creative Zen X-Fi Battery, Separating the Battery: 8 단계, 이미지 1/1
    • Use a spudger to pry the battery from the midsection plate.
    • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
  9. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: 9 단계, 이미지 1/2 Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: 9 단계, 이미지 2/2
    • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
    • Hold the battery wires in place so that access to the soldering joints is not blocked.
    • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
    • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Westley Courchene
회원 가입일: 01/13/15
3,389 평판
안내서 14개 작성하였습니다
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G1
5 회원들
안내서 14개 작성하였습니다
댓글 한 개
very clear pictures!
John - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 11
30일 전: 50
전체 시간: 6,809
