주요 콘텐츠로 건너뛰기
Replacing Creative Zen X-Fi Button Input Chip Part 1
필요한 것
  1. Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: 1 단계, 이미지 3개 중 1개 Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: 1 단계, 이미지 3개 중 2개 Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: 1 단계, 이미지 3개 중 3개
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Button Input Chip Part 1, Rubber Button Cover: 2 단계, 이미지 1개 중 1개
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Button Input Chip Part 1, Button Input Chip Part 1: 3 단계, 이미지 1개 중 1개
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Button Input Chip Part 1, Button Input Chip: 4 단계, 이미지 1개 중 1개
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
결론
작성자
2다른 기여자 명과 함께
Westley Courchene
회원 가입일: 01/13/15
3,410 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 419
