소개
The speaker is an output component that plays sound.
부품
부품은 필요하지 않습니다.
Using a spudger, wedge the tip between the front and back case to pry them apart.
Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
Lift open the LCD screen and button input chip to access the entire midsection plate.
Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case.
Once unscrewed, pick up the case and put it to the side.
With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
다른 한 분이 해당 안내서를 완성하였습니다.
