소개
Replacing the needle is one of the quick and easy. This does not requires opening the device and can be done in a matter of minutes.
필요한 것
The needle is the red plastic piece on the end of the arm. The needle snugly fits over the lower portion of the head, or front end, of the arm.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
On the Crosley CR7002A I am having a problem with the turntable. When the tone arm is moved over any part of the record is slides back to the home position (rest). Is their any adjustment I can make to fix this? Thanks.
