주요 콘텐츠로 건너뛰기
Replacing Crosley CR42 Needle
필요한 것
  1. Replacing Crosley CR42 Needle, Needle: 1 단계, 이미지 1/2 Replacing Crosley CR42 Needle, Needle: 1 단계, 이미지 2/2
    • The needle is the red plastic piece on the end of the arm. The needle snugly fits over the lower portion of the head, or front end, of the arm.
  2. Replacing Crosley CR42 Needle: 2 단계, 이미지 1/2 Replacing Crosley CR42 Needle: 2 단계, 이미지 2/2
    • While securing the end of the arm by holding the head in place, use your fingernail to push down on the front edge of the needle.
    • The needle should hang, as shown.
  3. Replacing Crosley CR42 Needle: 3 단계, 이미지 1/2 Replacing Crosley CR42 Needle: 3 단계, 이미지 2/2
    • Once the needle snaps free of the head of the arm, remove the needle by pulling down. Take care to only pull on the red portion.
    • WHEN ATTACHING NEW NEEDLE: Slide the back (open U shaped side) of the needle on first, then press to snap the front into place. You should hear a click.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Roberto Rosila
회원 가입일: 01/26/14
319 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-38, Maness Winter 2014 Cal Poly, Team 1-38, Maness Winter 2014 회원
CPSU-MANESS-W14S1G38
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
On the Crosley CR7002A I am having a problem with the turntable. When the tone arm is moved over any part of the record is slides back to the home position (rest). Is their any adjustment I can make to fix this? Thanks.
thmccullough - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 20
전체 시간: 5,137
