주요 콘텐츠로 건너뛰기
Replacing Crosley CR704 Needle
필요한 것
  1. Replacing Crosley CR704 Needle, Needle: 1 단계, 이미지 1개 중 1개
    • With steady hands, gently tug the needle from its cartridge pulling downwards.
    • There will be a slight resistance.
  2. Replacing Crosley CR704 Needle: 2 단계, 이미지 1개 중 1개
    • Secure the new needle by gently snapping it upwards an inwards until it clicks into place.
    • Be careful not to touch the stylus tip when handling the tone arm. This is what plays your records.
결론
Test by playing a record. We suggest "Revolver" by the Beatles.
작성자
2다른 기여자 명과 함께
MarkAnthony
회원 가입일: 09/22/13
826 평판
안내서 5개를 작성함
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S1G4
3 회원들
안내서 6개를 작성함
1가이드 댓글
2 steps with the same pic for both.
Really?
John Pottle - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 36
전체 시간: 18,556
