소개
This guide will demonstrate how to remove and replace the screen on an IBM ThinkPad 560z. A Phillips 00 screwdriver and a push pin are needed for this process.
부품
부품은 필요하지 않습니다.
  1. Slide the battery release latch to the right.
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Remove the plastic screw covers, then remove the 3 Phillips screws under them.
    • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
    • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
    • Remove the four Phillips head screws.
    • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
    • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
      • The connector is very fragile, so be careful.
결론
다른 2명이 해당 안내서를 완성하였습니다.
John Allande
회원 가입일: 2010년 04월 15일
64 평판
안내서 1개 작성함
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 회원
CPSU-REGAN-S10S26G27
3 회원들
안내서 18개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 4,541
