주요 콘텐츠로 건너뛰기
Replacing IBM ThinkPad 560z Speaker
필요한 것
  1. Replacing IBM ThinkPad 560z Speaker, Battery Removal: 1 단계, 이미지 1/1
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Replacing IBM ThinkPad 560z Speaker, Upper Case: 2 단계, 이미지 1/1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  3. Replacing IBM ThinkPad 560z Speaker: 3 단계, 이미지 1/2 Replacing IBM ThinkPad 560z Speaker: 3 단계, 이미지 2/2
    • Open the flap on the left hand side.
  4. Replacing IBM ThinkPad 560z Speaker: 4 단계, 이미지 1/2 Replacing IBM ThinkPad 560z Speaker: 4 단계, 이미지 2/2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  5. Replacing IBM ThinkPad 560z Speaker: 5 단계, 이미지 1/2 Replacing IBM ThinkPad 560z Speaker: 5 단계, 이미지 2/2
    • Open the flap on the right side.
  6. Replacing IBM ThinkPad 560z Speaker: 6 단계, 이미지 1/1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  7. Replacing IBM ThinkPad 560z Speaker: 7 단계, 이미지 1/2 Replacing IBM ThinkPad 560z Speaker: 7 단계, 이미지 2/2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  8. Replacing IBM ThinkPad 560z Speaker: 8 단계, 이미지 1/1
    • Use your fingers or a spudger to detach the connector.
  9. Replacing IBM ThinkPad 560z Speaker: 9 단계, 이미지 1/2 Replacing IBM ThinkPad 560z Speaker: 9 단계, 이미지 2/2
    • Carefully lift and remove the keyboard.
  10. Replacing IBM ThinkPad 560z Speaker, Speaker: 10 단계, 이미지 1/2 Replacing IBM ThinkPad 560z Speaker, Speaker: 10 단계, 이미지 2/2
    • Slowly and carefully lift the speaker with your fingers.
    • The port that the speaker plugs into can be easily removed from the motherboard if not careful! Unplug the speaker with extreme caution!
  11. Replacing IBM ThinkPad 560z Speaker: 11 단계, 이미지 1/2 Replacing IBM ThinkPad 560z Speaker: 11 단계, 이미지 2/2
    • Use your fingers to unplug the wires from the connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Derek Driscoll
회원 가입일: 04/15/10
119 평판
안내서 8개 작성하였습니다
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 회원
CPSU-REGAN-S10S26G27
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,740
