소개
Step-by-step guide to replacing your phone's logic board.
부품
부품은 필요하지 않습니다.
  1. Flip phone to see back cover. Using either finger or spugder tool press button located  near the top of phone by the antenna.
    • Flip phone to see back cover.
    • Using either finger or spugder tool press button located near the top of phone by the antenna.
  2. Pry up back plate from phone to reveal battery. Push button near bottom of battery using either your finger of the spudger.  This will release the battery.
    • Pry up back plate from phone to reveal battery.
    • Push button near bottom of battery using either your finger of the spudger. This will release the battery.
  3. Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
    • Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Simultaneously press indicated buttons on both sides of phone. Simultaneously press indicated buttons on both sides of phone.
    • Simultaneously press indicated buttons on both sides of phone.
  6. Separate back plate from the rest of phone.
    • Separate back plate from the rest of phone.
    • Make sure to not pull, there is a wire (circled on image) connecting the two plates.
  7. Gently lift logic board from back plate.
    • Gently lift logic board from back plate.
  8. Place logic board on front cover. Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
결론
Elizabeth OBrien
회원 가입일: 2010년 04월 26일
31 평판
안내서 7개 작성하였습니다
Cal Poly, Team 30-40, Garner Spring 2010 Cal Poly, Team 30-40, Garner Spring 2010 회원
CPSU-GARNER-S10S30G40
4 회원들
안내서 14개 작성하였습니다
Quero comprar esse aparelho, alguém tem para vender?
Karison Mesquita - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 11
전체 시간: 1,976
