소개
Use this guide to replace the LCD.
필요한 것
Open the battery cover.
Separate the rear cover from the front by simply gently pulling the two halves apart. You may have to use your fingernails to separate them. Start at the bottom side, by the AC Power cover. Work your way around the bottom.
Once the bottom part of the halves is released, gently pull the back cover in an upward motion. The top is secured by some tabs to the front part.
When you remove this screw, make sure that the shield plate on top of the bracket plate, is just slightly pushed out of the way. This will free the bracket plate.
After the removal of the bracket plate, you have access to the connector. Move the white clip gently to the lift (upright) position, to free the cable.
The LCD should now easily separate from the logic board.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 3개
Very good, I really appreciate it. Thank you.
where did you buy the replacement lcd? my l20 broke recently and i’m trying to fix it.
@katherinelam had to be either ebay or aliexpress. It's been to long ago to remember for sure.
