주요 콘텐츠로 건너뛰기
Replacing Nokia Classic 2600c-2b Faceplate
필요한 것
  1. Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: 1 단계, 이미지 1/2 Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: 1 단계, 이미지 2/2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Replacing Nokia Classic 2600c-2b Faceplate: 2 단계, 이미지 1/1
    • Remove the back cover to expose the battery.
  3. Replacing Nokia Classic 2600c-2b Faceplate: 3 단계, 이미지 1/2 Replacing Nokia Classic 2600c-2b Faceplate: 3 단계, 이미지 2/2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Replacing Nokia Classic 2600c-2b Faceplate: 4 단계, 이미지 1/2 Replacing Nokia Classic 2600c-2b Faceplate: 4 단계, 이미지 2/2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Replacing Nokia Classic 2600c-2b Faceplate: 5 단계, 이미지 1/1
    • Remove the faceplate with the number pad attached.
  6. Replacing Nokia Classic 2600c-2b Faceplate: 6 단계, 이미지 1/1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
    • Apply new faceplate.
    • Follow the instructions in reverse order to reassemble the phone.
결론
Ian VanZandt
회원 가입일: 02/14/12
654 평판
안내서 5개 작성하였습니다
James Madison, Team 3-1, Klein Spring 2012 James Madison, Team 3-1, Klein Spring 2012 회원
JMU-KLEIN-S12S3G1
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 397
