메인 컨텐츠로 가기
  1. Before disassembling your phone, be sure it is powered off. To remove the back cover press the two "buttons". Remove the battery.
    • Before disassembling your phone, be sure it is powered off.
    • To remove the back cover press the two "buttons".
    • Remove the battery.
  2. Remove the three 3mm black screws on the top of the phone. Remove the two 5mm screws.
    • Remove the three 3mm black screws on the top of the phone.
    • Remove the two 5mm screws.
    • Loosen these two screws at the bottom of the phone.
    • Probably these screws will not come out from their home, no matter. It is only important to unscrew them completely.
  3. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  4. With a plastic opening tool remove the little piece of plastic in the bottom of of the phone. The two corners marked are VERY SLENDER, when removing the plastic be very careful. Otherwise you will break them. To remove the logic board assembly push from the rear of the phone.
    • With a plastic opening tool remove the little piece of plastic in the bottom of of the phone.
    • The two corners marked are VERY SLENDER, when removing the plastic be very careful. Otherwise you will break them.
    • To remove the logic board assembly push from the rear of the phone.
  5. Remove the keyboard with a plastic opening tool. Remove the keyboard with a plastic opening tool.
    • Remove the keyboard with a plastic opening tool.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Matteo Moro
회원 가입일: 2013년 02월 21일
476 Reputation
안내서 1개 작성함
댓글 0개
댓글 쓰기
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 4,335
