소개
It is fairly simple to replace the bread lift shelf, even though the metal flaps holding the bread lift shelf can be difficult to access.
필요한 것
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Use a flat-head screwdriver to separate the metal flap from the metal plate.
거의 끝나갑니다!
결론
