주요 콘텐츠로 건너뛰기
Replacing Oster 6329 Bread Lift Shelf
필요한 것
  1. Replacing Oster 6329 Bread Lift Shelf, Outer Shell Removal: 1 단계, 이미지 1/2 Replacing Oster 6329 Bread Lift Shelf, Outer Shell Removal: 1 단계, 이미지 2/2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Replacing Oster 6329 Bread Lift Shelf: 2 단계, 이미지 1/1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Replacing Oster 6329 Bread Lift Shelf: 3 단계, 이미지 1/1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Replacing Oster 6329 Bread Lift Shelf: 4 단계, 이미지 1/2 Replacing Oster 6329 Bread Lift Shelf: 4 단계, 이미지 2/2
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Replacing Oster 6329 Bread Lift Shelf: 5 단계, 이미지 1/2 Replacing Oster 6329 Bread Lift Shelf: 5 단계, 이미지 2/2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Replacing Oster 6329 Bread Lift Shelf, Bread Lift Shelf: 6 단계, 이미지 1/1
    • Use a flat-head screwdriver to separate the metal flap from the metal plate.
  7. Replacing Oster 6329 Bread Lift Shelf: 7 단계, 이미지 1/2 Replacing Oster 6329 Bread Lift Shelf: 7 단계, 이미지 2/2
    • Grasp the metal flap with the large needle nose pliers.
    • Unbend metal flap until at a 90 degree angle from the metal plate.
    • Repeat these steps for the second metal flap.
  8. Replacing Oster 6329 Bread Lift Shelf: 8 단계, 이미지 1/1
    • Use the large need nose pliers to grab the metal panel.
    • Pull the metal panel away from the body of the toaster to dislodge the flaps.
  9. Replacing Oster 6329 Bread Lift Shelf: 9 단계, 이미지 1/2 Replacing Oster 6329 Bread Lift Shelf: 9 단계, 이미지 2/2
    • Push the metal flaps towards the body of the toaster to access the bread lift shelf.
  10. Replacing Oster 6329 Bread Lift Shelf: 10 단계, 이미지 1/1
    • Push down on the opposite side of the bread lift shelf to expose the metal flaps.
  11. Replacing Oster 6329 Bread Lift Shelf: 11 단계, 이미지 1/1
    • Pull up on the bread lift shelf to remove from the toaster.
결론
Jason Yoon
회원 가입일: 01/31/14
101 평판
안내서 1개 작성함
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014 회원
CPSU-REGAN-W14S13G15
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 610
