주요 콘텐츠로 건너뛰기
Replacing Samsung Galaxy S4 SIM Card
필요한 것
  1. Replacing Samsung Galaxy S4 SIM Card, Rear Case: 1 단계, 이미지 1/2 Replacing Samsung Galaxy S4 SIM Card, Rear Case: 1 단계, 이미지 2/2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Replacing Samsung Galaxy S4 SIM Card: 2 단계, 이미지 1/3 Replacing Samsung Galaxy S4 SIM Card: 2 단계, 이미지 2/3 Replacing Samsung Galaxy S4 SIM Card: 2 단계, 이미지 3/3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: 3 단계, 이미지 1/3 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: 3 단계, 이미지 2/3 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: 3 단계, 이미지 3/3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  4. Replacing Samsung Galaxy S4 SIM Card, Battery: 4 단계, 이미지 1/3 Replacing Samsung Galaxy S4 SIM Card, Battery: 4 단계, 이미지 2/3 Replacing Samsung Galaxy S4 SIM Card, Battery: 4 단계, 이미지 3/3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Replacing Samsung Galaxy S4 SIM Card, SIM Card: 5 단계, 이미지 1/3 Replacing Samsung Galaxy S4 SIM Card, SIM Card: 5 단계, 이미지 2/3 Replacing Samsung Galaxy S4 SIM Card, SIM Card: 5 단계, 이미지 3/3
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
결론
다른 78명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,611 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,731개 작성하였습니다
댓글 3개
Can you take one sim card slot out one galaxy s4 and put it in another or do u have to buy a new one
marius williams - 답글
Somethings wrong with sim card start shut out since July 5 evening and today July 6 three times
humeston23 - 답글
Removing sim card tray?
G M Chadwick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 83
30일 전: 279
전체 시간: 245,674
