소개
A guide to remove power block from the Sega Dreamcast.
부품
부품은 필요하지 않습니다.
  1. Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  6. Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working. Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
    • Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working.
    • Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
  7. Remove the two 10mm Philips #02 screws that are fastened to the power block.
    • Remove the two 10mm Philips #02 screws that are fastened to the power block.
  8. Do not bend the male pin header between the mounted head when you remove the power supply from the chassis. Remove the power board by using both hands to gently lift the power board away from the console.
    • Do not bend the male pin header between the mounted head when you remove the power supply from the chassis.
    • Remove the power board by using both hands to gently lift the power board away from the console.
  9. Remove the clear plastic film that is tucked between the power supply and the chassis.
    • Remove the clear plastic film that is tucked between the power supply and the chassis.
결론
다른 8명이 해당 안내서를 완성하였습니다.
wkwong
회원 가입일: 2009년 11월 14일
426 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 회원
CPSU-REGAN-F09S5G1
5 회원들
안내서 18개 작성하였습니다
All symptoms of dead PSU can be occuring, if by accident flat ribbon cable between motherboard and controller board is disconnected. Check that cable if both ends is firmly plugged.
lauraiss lv - 답글
Hello There!
i turn on my dreamcast, No video, GD don´t spin, but the orange led barely shine, this happened many years ago (2003) , i just bought another DC in those days because i was in a hurry to end Grandia 2, and now i still have the damaged console in my room and im wondering if it is possible to fix it ...thanks!
Mardito Online - 답글
Very good and Panico
Mikesin - 답글
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 79
전체 시간: 11,930
