주요 콘텐츠로 건너뛰기
Replacing Spring in Refrigerator Door
필요한 것
  1. Replacing Spring in Refrigerator Door, Spring: 1 단계, 이미지 1개 중 1개
    • Turn off the refrigerator by unplugging it or turning the breaker off.
    • There are electrical cords attaching the assembly flap to the door, so it is better to be safe.
  2. Replacing Spring in Refrigerator Door: 2 단계, 이미지 2개 중 1개 Replacing Spring in Refrigerator Door: 2 단계, 이미지 2개 중 2개
    • With a Phillips screwdriver, unscrew and remove the two screws on the hinge located directly in the middle of the door, connecting the assembly flap to the door.
  3. Replacing Spring in Refrigerator Door: 3 단계, 이미지 2개 중 1개 Replacing Spring in Refrigerator Door: 3 단계, 이미지 2개 중 2개
    • Located at the bottom of the assembly flap, remove the bottom plastic piece by gently shimmying it out with a small flat head screwdriver.
    • This may be a bit difficult.
  4. Replacing Spring in Refrigerator Door: 4 단계, 이미지 2개 중 1개 Replacing Spring in Refrigerator Door: 4 단계, 이미지 2개 중 2개
    • Carefully lift the assembly flap upward guiding it along the top and bottom plastic hinge just before it comes off.
  5. Replacing Spring in Refrigerator Door: 5 단계, 이미지 3개 중 1개 Replacing Spring in Refrigerator Door: 5 단계, 이미지 3개 중 2개 Replacing Spring in Refrigerator Door: 5 단계, 이미지 3개 중 3개
    • On the bottom of the assembly flap, carefully insert the spring into the plastic holes. One is connected to the bottom plastic hinge and the other is attached to the assembly flap.
    • Slide the assembly flap down into place. Be sure the top and bottom plastic hinge slides into place. You’ll notice the spring securely sliding into the plastic holes.
  6. Replacing Spring in Refrigerator Door: 6 단계, 이미지 2개 중 1개 Replacing Spring in Refrigerator Door: 6 단계, 이미지 2개 중 2개
    • Re-insert the bottom plastic piece by pressing it in until it snaps.
  7. Replacing Spring in Refrigerator Door: 7 단계, 이미지 3개 중 1개 Replacing Spring in Refrigerator Door: 7 단계, 이미지 3개 중 2개 Replacing Spring in Refrigerator Door: 7 단계, 이미지 3개 중 3개
    • Replace the two screws on the middle, metal hinge.
    • Turn the power on. Fast Fix is complete.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Christine Meyers
회원 가입일: 01/15/18
271 평판
안내서 1개를 작성함
1가이드 댓글
Very helpful! Easily completed and solved my problem.
Stephen Joncus - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 29
지난 30일: 129
전체 시간: 15,589
