주요 콘텐츠로 건너뛰기
Replacing Strings on a Mandolin
필요한 것
  1. Replacing Strings on a Mandolin, Mandolin Strings: 1 단계, 이미지 1/1
    • Place the mandolin on a firm, level surface with adequate lighting.
  2. Replacing Strings on a Mandolin: 2 단계, 이미지 1/1
    • Loosen the tuning nob.
    • Carefully remove the top end of string from the tuner in the mandolin head.
  3. Replacing Strings on a Mandolin: 3 단계, 이미지 1/1
    • Unhook the old string from the tail of the mandolin.
    • Remove the string from the bottom.
  4. Replacing Strings on a Mandolin: 4 단계, 이미지 1/1
    • Select a new string, and then insert the bottom end of it through the bridge at the tail.
  5. Replacing Strings on a Mandolin: 5 단계, 이미지 1/1
    • Secure the string to the tail by looping it over the hook.
  6. Replacing Strings on a Mandolin: 6 단계, 이미지 1/1
    • Pulling the string taut, bring its top end across the nut and into the tuning peg.
  7. Replacing Strings on a Mandolin: 7 단계, 이미지 1/1
    • Run the line through the tuning element at the head of the mandolin, as pictured. Be sure to pull the string away from the headstock.
  8. Replacing Strings on a Mandolin: 8 단계, 이미지 1/2 Replacing Strings on a Mandolin: 8 단계, 이미지 2/2
    • Pull the string down, towards the fretboard, and run the string underneath itself.
    • Pull the string tight so that it wraps around the tuning peg.
  9. Replacing Strings on a Mandolin: 9 단계, 이미지 1/1
    • Pinch the string over itself to create a knot.
  10. Replacing Strings on a Mandolin: 10 단계, 이미지 1/1
    • Tighten the tuning nob until the desired tension is reached.
  11. Replacing Strings on a Mandolin: 11 단계, 이미지 1/1
    • Clip off any excess string.
  12. Replacing Strings on a Mandolin: 12 단계, 이미지 1/1
    • Optional: Clip the electronic tuning device to the head of the mandolin; use the device to assist in fine-tuning your mandolin.
  13. Replacing Strings on a Mandolin: 13 단계, 이미지 1/1
    • Commence rocking on with your Gretsch New Yorker!
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Drew
회원 가입일: 03/18/15
125 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 18
전체 시간: 7,445
