주요 콘텐츠로 건너뛰기
Replacing VTech MobiGo Touch Learning System Speaker
필요한 것
  1. Replacing VTech MobiGo Touch Learning System Speaker, Case: 1 단계, 이미지 1개 중 1개
    • Remove the battery covers and the four batteries.
  2. Replacing VTech MobiGo Touch Learning System Speaker: 2 단계, 이미지 2개 중 1개 Replacing VTech MobiGo Touch Learning System Speaker: 2 단계, 이미지 2개 중 2개
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Replacing VTech MobiGo Touch Learning System Speaker: 3 단계, 이미지 2개 중 1개 Replacing VTech MobiGo Touch Learning System Speaker: 3 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Replacing VTech MobiGo Touch Learning System Speaker, Speaker: 4 단계, 이미지 2개 중 1개 Replacing VTech MobiGo Touch Learning System Speaker, Speaker: 4 단계, 이미지 2개 중 2개
    • The speaker will be attached to the back of the case.
    • Unscrew the two 6.0 mm Philips J0 screws.
    • Careful! The wires are still attached to the back of the case and to the speakers.
  5. Replacing VTech MobiGo Touch Learning System Speaker: 5 단계, 이미지 2개 중 1개 Replacing VTech MobiGo Touch Learning System Speaker: 5 단계, 이미지 2개 중 2개
    • Lift the round speaker with a plastic opening tool.
    • Remove the two wires connected to the speaker.
    • You can use wire cutters or regular needle nose pliers to disconnect the wires from the speaker.
    • Once the wires are disconnected, remove the speaker from the back of the case.
  6. Replacing VTech MobiGo Touch Learning System Speaker: 6 단계, 이미지 2개 중 1개 Replacing VTech MobiGo Touch Learning System Speaker: 6 단계, 이미지 2개 중 2개
    • Solder the wires to the appropriate spots on the new speaker, making sure that both wires are properly connected.
    • The wires may be hot.
  7. Replacing VTech MobiGo Touch Learning System Speaker: 7 단계, 이미지 2개 중 1개 Replacing VTech MobiGo Touch Learning System Speaker: 7 단계, 이미지 2개 중 2개
    • Insert the new speaker into the hatch located in the middle part of the panel using a plastic spudger.
    • Make sure the speaker is the right size for the panel.
    • Once the speaker is properly placed, screw in the two 6.0 mm Philips J0 screws.
    • Do not over tighten the screws or the panel will break.
결론
To reassemble your case, follow the case instructions in reverse order.
작성자
3다른 기여자 명과 함께
RBansil
회원 가입일: 08/27/15
221 평판
안내서 2개를 작성함
USF Tampa, Team 8-3, Eyestone Fall 2015 USF Tampa, Team 8-3, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G3
3 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 35
지난 30일: 214
전체 시간: 1,890
