주요 콘텐츠로 건너뛰기
Replacing VuPoint DC-ST210-VP View Finder
필요한 것
  1. Replacing VuPoint DC-ST210-VP View Finder, Turn Off/Remove Batteries: 1 단계, 이미지 1개 중 1개
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: 2 단계, 이미지 3개 중 1개 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: 2 단계, 이미지 3개 중 2개 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: 2 단계, 이미지 3개 중 3개
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: 3 단계, 이미지 2개 중 1개 Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: 3 단계, 이미지 2개 중 2개
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. Replacing VuPoint DC-ST210-VP View Finder, Remove View Finder: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use fingers or tweezers to gently lift view finder out of socket.
    • Clean with general lens cleaner and microfiber fabric as necessary and replace.
결론
작성자
4다른 기여자 명과 함께
Dorey Chiu
회원 가입일: 10/26/14
1 평판
안내서 1개를 작성함
Baylor, Team 8-15, Williams Fall 2014 Baylor, Team 8-15, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G15
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 420
