주요 콘텐츠로 건너뛰기
Replacing a Baseball Bat Grip
필요한 것
  1. Replacing a Baseball Bat Grip, Baseball Bat Grip: 1 단계, 이미지 3개 중 1개 Replacing a Baseball Bat Grip, Baseball Bat Grip: 1 단계, 이미지 3개 중 2개 Replacing a Baseball Bat Grip, Baseball Bat Grip: 1 단계, 이미지 3개 중 3개
    • Place the bat on a firm surface with the grip hanging off the edge.
    • Draw a line on the top of the old grip using a marker.
    • Practice caution when using the utility knife.
    • Use the utility knife to cut the tape where you made your mark.
    • Peel off the old grip.
    • Some bats may have an under layer of wrap that will require extra peeling to remove.
  2. Replacing a Baseball Bat Grip: 2 단계, 이미지 2개 중 1개 Replacing a Baseball Bat Grip: 2 단계, 이미지 2개 중 2개
    • Put on gloves and place the paper towels under the bat handle to catch the excess spilled residue cleaner.
    • Apply the residue cleaner to the handle.
    • Scrub off the residue with a rag.
  3. Replacing a Baseball Bat Grip: 3 단계, 이미지 3개 중 1개 Replacing a Baseball Bat Grip: 3 단계, 이미지 3개 중 2개 Replacing a Baseball Bat Grip: 3 단계, 이미지 3개 중 3개
    • Sit in a chair and hold the bat in-between your legs with the knob facing upwards.
    • Take the pre-wrap, begin at the knob of the bat and wrap downward in a spiraling motion toward the mark.
    • When applying the pre-wrap, be sure to keep it evenly layered as it will quickly get thicker when doubled.
    • Stop applying the prewrap at the marked line.
  4. Replacing a Baseball Bat Grip: 4 단계, 이미지 3개 중 1개 Replacing a Baseball Bat Grip: 4 단계, 이미지 3개 중 2개 Replacing a Baseball Bat Grip: 4 단계, 이미지 3개 중 3개
    • Hold the bat in the same position used for applying the pre-wrap.
    • Apply the electrical tape over the previous wrap using the same motion as before.
    • Be sure to evenly layer the tape to have a smooth wrap all the way down the handle.
  5. Replacing a Baseball Bat Grip: 5 단계, 이미지 2개 중 1개 Replacing a Baseball Bat Grip: 5 단계, 이미지 2개 중 2개
    • Apply a small piece of electrical tape at the beginning and end of the wrap to fasten it to the bat.
    • Now that your new grip is complete, you're ready to play ball!
결승점
다른 9명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Matthew McNabb
회원 가입일: 09/11/15
164 평판
안내서 1개를 작성함
Sam Houston State, Team 16-6, Nardone Fall 2015 Sam Houston State, Team 16-6, Nardone Fall 2015 회원
SHSU-NARDONE-F15S16G6
5 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 43
전체 시간: 65,668
