이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Place the bat on a firm surface with the grip hanging off the edge.
Draw a line on the top of the old grip using a marker.
Use the utility knife to cut the tape where you made your mark.
Peel off the old grip.
Apply the residue cleaner to the handle.
Scrub off the residue with a rag.
Sit in a chair and hold the bat in-between your legs with the knob facing upwards.
Take the pre-wrap, begin at the knob of the bat and wrap downward in a spiraling motion toward the mark.
Stop applying the prewrap at the marked line.
Hold the bat in the same position used for applying the pre-wrap.
Apply the electrical tape over the previous wrap using the same motion as before.
Apply a small piece of electrical tape at the beginning and end of the wrap to fasten it to the bat.
Now that your new grip is complete, you're ready to play ball!
다른 9명이 해당 안내서를 완성하였습니다.
댓글 2개
To reverse the previous wrap, try to locate its end. To start from there gently, try using a cutting knife to pull off an end.
The additional stickers you previously applied should be removed after unwinding the tape.
Take off all tape, adhesive, and residue from the bat. Even so, anticipate some goo to be visible on the bat's handle. This can be taken off by gently rubbing it with fine-grit sandpaper. Cut a tiny rectangle out of the sandpaper. When using, use mild, unidirectional strokes.
Be aware of how high you want to wrap your bat before beginning the actual wrapping process. MLB regulations allow grip tape to be applied up to 18 inches up a bat's handle.
Mathew, you explained quite well. I have linked one picture for your article. The "Baseball bat care"
Do you have to take off the original batting grip?
