주요 콘텐츠로 건너뛰기
Replacing a Sprinkler Extension
필요한 것
  1. Replacing a Sprinkler Extension, Sprinkler Extension: 1 단계, 이미지 1/1
    • Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
    • The pipe fitting is usually about one foot underground.
  2. Replacing a Sprinkler Extension: 2 단계, 이미지 1/1
    • Dig around the pipe fitting with a trowel to provide clear access.
  3. Replacing a Sprinkler Extension: 3 단계, 이미지 1/1
    • Clean the area around the fitting with water until the fitting is mostly free of dirt.
  4. Replacing a Sprinkler Extension: 4 단계, 이미지 1/2 Replacing a Sprinkler Extension: 4 단계, 이미지 2/2
    • Unscrew the sprinkler extension from the pipe fitting.
    • Once the extension is removed, water may come out of the open pipe fitting.
  5. Replacing a Sprinkler Extension: 5 단계, 이미지 1/1
    • Screw the new sprinkler extension in securely.
  6. Replacing a Sprinkler Extension: 6 단계, 이미지 1/2 Replacing a Sprinkler Extension: 6 단계, 이미지 2/2
    • Test the sprinkler to ensure that there are no leaks.
    • Refill the hole tightly.
결론
If you have completed the steps successfully you should have a fully functioning sprinkler extension.
Abagayle Serreyn
회원 가입일: 09/11/15
111 평판
안내서 1개 작성함
Sam Houston State, Team 16-5, Nardone Fall 2015 Sam Houston State, Team 16-5, Nardone Fall 2015 회원
SHSU-NARDONE-F15S16G5
5 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 12
전체 시간: 802
