주요 콘텐츠로 건너뛰기
Replacing a TAE/DSL Socket with a RJ45 Jack
필요한 것
  1. Replacing a TAE/DSL Socket with a RJ45 Jack, Remove the old socket: 1 단계, 이미지 2개 중 1개 Replacing a TAE/DSL Socket with a RJ45 Jack, Remove the old socket: 1 단계, 이미지 2개 중 2개
    • Unscrew and remove the cover.
    • If you want to add an RJ45 jack but only have access to the first (non-replaceable) TAE outlet, you can mount the new RJ45 outlet next to it. Connect La on the new outlet to pin 6 of the old TAE outlet, and Lb to pin 5. You can use any type of shielded twisted pair cable for the connection.
    • Remove the the connections.
    • Keep track of La and Lb. You’ll need to know what wires to connect where in the new socket.
    • Unscrew the socket from the wall.
  2. Replacing a TAE/DSL Socket with a RJ45 Jack, Mount the new socket: 2 단계, 이미지 1개 중 1개
    • Screw the new socket cover to the wall.
    • Refer to the manual that came with your outlet for this step.
  3. Replacing a TAE/DSL Socket with a RJ45 Jack, Punch down the wires: 3 단계, 이미지 1개 중 1개
    • If you don’t know how to use a punch down tool, take a look at this guide first.
    • Connect La to pin 4 (Blue).
    • Connect Lb to pin 5 (White-Blue).
  4. Replacing a TAE/DSL Socket with a RJ45 Jack, Mount the socket: 4 단계, 이미지 1개 중 1개
    • Mount the RJ45 socket inside the case and screw on the faceplate.
결론
Have fun surfing the web!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
31,221 평판
안내서 71개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 42
지난 7일: 293
지난 30일: 1,409
전체 시간: 22,833
