주요 콘텐츠로 건너뛰기
Replacing a Wheel on your Patagonia Wheeled Luggage
필요한 것
  1. Replacing a Wheel on your Patagonia Wheeled Luggage, Wheel: 1 단계, 이미지 1/1
    • Lay the bag down, with the problem wheel facing you.
    • Zipping the bag closed will keep it from flopping about as you work.
  2. Replacing a Wheel on your Patagonia Wheeled Luggage: 2 단계, 이미지 1/3 Replacing a Wheel on your Patagonia Wheeled Luggage: 2 단계, 이미지 2/3 Replacing a Wheel on your Patagonia Wheeled Luggage: 2 단계, 이미지 3/3
    • Using a hex 4.0 screwdriver, remove the threaded bolt in the center of of the wheel. This is the screw closest to the ground when the bag is upright.
    • Remove the bolt by pulling it straight out of the hole.
  3. Replacing a Wheel on your Patagonia Wheeled Luggage: 3 단계, 이미지 1/2 Replacing a Wheel on your Patagonia Wheeled Luggage: 3 단계, 이미지 2/2
    • Using one hand to lift and support the bag, take the wheel in your other hand. Pull the wheel out of its casing.
    • Removing the wheel may take a little force, do not be afraid to give it a tug.
    • To install your replacement wheel, follow these steps in reverse order with your new wheel.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,011 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,732개 작성하였습니다
댓글 2개
What do you do when the nut inside the wheel housing comes loose? I can hear it rolling around in the housing. The bolt has nothing to screw back into. Is there any way to take the housing off? It looks to be held on by rivets. I'm guessing that's not a good sign.
Derek Emanuel - 답글
Helpful but where do you get the replacement wheel from. My brand new Black Hole 100L bag showed up in Lisbon Portugal with one wheel missing. Need to get another wheel and screw. Can I order that from Patagonia and have them ship to a friend that is coming here? Is that best route to take? Thanks
Craig Klinger - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 80
전체 시간: 10,998
