주요 콘텐츠로 건너뛰기
Replacing a Zipper Pull Tab on your Patagonia Jacket
동영상 개요
Zipper pull replacement overview.
  1. Replacing a Zipper Pull Tab on your Patagonia Jacket, Zipper Pull Tab: 1 단계, 이미지 1/2 Replacing a Zipper Pull Tab on your Patagonia Jacket, Zipper Pull Tab: 1 단계, 이미지 2/2
    • Get your new zipper pull and position it with the pull-tab down.
    • Lift up the zipper, as if you were pulling the zipper closed.
  2. Replacing a Zipper Pull Tab on your Patagonia Jacket: 2 단계, 이미지 1/3 Replacing a Zipper Pull Tab on your Patagonia Jacket: 2 단계, 이미지 2/3 Replacing a Zipper Pull Tab on your Patagonia Jacket: 2 단계, 이미지 3/3
    • Insert the zipper pull into the smaller hole in the zipper. This is the top hole when the zipper is hanging normally.
    • Pull the zipper pull through the smaller hole.
  3. Replacing a Zipper Pull Tab on your Patagonia Jacket: 3 단계, 이미지 1/2 Replacing a Zipper Pull Tab on your Patagonia Jacket: 3 단계, 이미지 2/2
    • Rest the zipper back in its normal, hanging position.
    • Take top end of the zipper pull and insert it into the bigger, lower hole in the zipper.
  4. Replacing a Zipper Pull Tab on your Patagonia Jacket: 4 단계, 이미지 1/2 Replacing a Zipper Pull Tab on your Patagonia Jacket: 4 단계, 이미지 2/2
    • Pull the top of the zipper pull through the hole to create a loop on the backside of the zipper.
    • Bring the zipper pull-tab through the loop.
  5. Replacing a Zipper Pull Tab on your Patagonia Jacket: 5 단계, 이미지 1/2 Replacing a Zipper Pull Tab on your Patagonia Jacket: 5 단계, 이미지 2/2
    • Pull the zipper pull-tab snug.
    • The zipper pull should now be inserted and lay flat.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
88,898 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 16,560개 작성하였습니다
댓글 한 개
Awesome! Thanks for the training!
Kathleen Hutton - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 50
30일 전: 194
전체 시간: 24,343
