주요 콘텐츠로 건너뛰기
Replacing accessory belt and rollers
  1. Replacing accessory belt and rollers, Accessing the engine hood: 1 단계, 이미지 1개 중 1개
    • Open the trunk.
    • Put aside the trunk carpets.
  2. Replacing accessory belt and rollers, Acessing the engine compartment: 2 단계, 이미지 1개 중 1개
    • Unscrew the 6 T50 screws by hand or using a wrench and a socket.
    • Lift and put aside the engine hood.
  3. Replacing accessory belt and rollers, Remove the accessory belt protective cover: 3 단계, 이미지 1개 중 1개
    • Remove the 4 screws from the belt protection cover using a 10mm wrench.
    • Remove the protective cover from the belt.
  4. Replacing accessory belt and rollers, Release and remove the accessory belt: 4 단계, 이미지 2개 중 1개 Replacing accessory belt and rollers, Release and remove the accessory belt: 4 단계, 이미지 2개 중 2개
    • Our aim is to have a colored tensioner like the one shown in the picture and like the new tensioner.
    • Use a 13mm hexagonal wrench and place it on the tensioner.
    • Turn the tensioner clockwise until you can insert a 4mm-thick pin into the hole and lock it in this position.
    • The tensioner is now locked and the accessory belt has loosened. It can now be removed.
  5. Replacing accessory belt and rollers, Replacing the tensioner roller: 5 단계, 이미지 2개 중 1개 Replacing accessory belt and rollers, Replacing the tensioner roller: 5 단계, 이미지 2개 중 2개
    • Remove the single 13mm hexagonal screw from the tensioner and pull it out.
    • Fit the new tensioner roller, ensuring that the pin is correctly positioned.
    • Tighten the single new 13mm screw to 62 N/m.
    • Keep the tensioner in place for belt replacement.
  6. Replacing accessory belt and rollers, Replacing the winding roller: 6 단계, 이미지 2개 중 1개 Replacing accessory belt and rollers, Replacing the winding roller: 6 단계, 이미지 2개 중 2개
    • Use a screwdriver to remove the cap from the winding roller.
    • Remove the single 13mm screw from the winding roller.
    • Fit the new winding roller and tighten the single new 13mm screw to a torque of 50 N/m.
  7. Replacing accessory belt and rollers, Replacing the accessory belt: 7 단계, 이미지 3개 중 1개 Replacing accessory belt and rollers, Replacing the accessory belt: 7 단계, 이미지 3개 중 2개 Replacing accessory belt and rollers, Replacing the accessory belt: 7 단계, 이미지 3개 중 3개
    • The idler roller must be in the slack position and tapped. If this is not the case, refer to step 2 to adjust it.
    • Install the accessory belt in the correct position, depending on whether or not the vehicle is fitted with an air-conditioning compressor. Make sure the belt passes correctly over the pulleys.
  8. Replacing accessory belt and rollers, Releasing the tensioner: 8 단계, 이미지 2개 중 1개 Replacing accessory belt and rollers, Releasing the tensioner: 8 단계, 이미지 2개 중 2개
    • Using a 13mm hex wrench, release the tensioner roller to remove the pin and return it to the tensioned position.
    • Turn the crankshaft pulley two revolutions clockwise with a 19mm socket wrench to ensure that the belt turns and is positioned correctly.
  9. Replacing accessory belt and rollers, Replace belt cover: 9 단계, 이미지 1개 중 1개
    • Replace the accessory belt cover and tighten the 4x 10mm screws to 10 N/m.
    • No tightening torque is recommended by the RTA. The torque given is a suggestion.
결론
Felicitations! You've just replaced your accessory belt and rollers!
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
AntonioTwingo
회원 가입일: 08/24/22
7,572 평판
안내서 45개를 작성함
5가이드 댓글
Hi! Is this good for SCe 75 engines too? I got a Dacia Sandero II with a B4D 411 engine and i was wondering if i could use this guide to change my parts too
Árpád Kis - 답글
Hi ! This tutorial is not applicable to your B4D 411 engine, part number 8201704417. The belt routing on this engine looks very different from the pictures I found online.
Other than than, many parts are different on this engine, including the injectors and all.
However, you might find some useful information on those links:
https://www.catcar.info/renault/?lang=en... (various schematics)
https://www.youtube.com/watch?v=IoF0ixzo... (B4D 422, also known as B4D LS, for Low-Spec)
AntonioTwingo -
Bjr pouvez vous me dire ou ce trouve le calculateur
Lucas - 답글
Bonjour,
Il y a plusieurs calculateurs dans les Twingo III. Pouvez-vous préciser quel calculateur ?
Si vous faisiez référence au calculateur moteur (ECU):
Renault Twingo III Phase 1 (2014-2019)
AntonioTwingo -
Merci bcp pour votre reponse je cherche bien l'emplacement du calculateur moteur car j'ai bien cherché coté droit du coffre dans les garnitures et je n'ai rien trouvé.
Lucas - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 64
지난 30일: 306
전체 시간: 7,275
