소개
A simple repair for bObsweep's ground sensors, which includes opening Bob, replacing the sensors, and closing your vacuum.
필요한 것
Flip Bob over and remove the 7 screws around which hold the cover together.
Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release each from the motherboard.
1. On the bottom left corner: a small connector with red, black and white wires.
2. One thick white wire that attaches on the right side of the previous connector.
3. On the top edge of bOb’s motherboard: a wide multicoloured connector.
Place the cover aside and begin your repair.
There are four ground detecting sensors inside bObsweep, found in front of the main board.
Use your screwdriver to remove all 8 screws holding the sensors in place. There are 2 on each sensor.
Install all 8 screws holding the ground detection sensors in place.
Proceed to the Closing bObsweep guide:Closing bObsweep's cover after repair
When finished, bObsweep will be able to detect the floor beneath and avoid dangerous falls off ledges or down staircases. To reassemble the core, see the Closing bOb Guide.
댓글 한 개
Great instructions. Where can i find to buy the sensors? do you have a specific webpage? Regards
Marcus (marcuswerner@gmx.de)
