소개
Directions on removing bObsweep standard's LCD display and replacing with a new one.
Video guide:
필요한 것
동영상 개요
Flip Bob over and remove the 7 screws around which hold the cover together.
Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release each from the motherboard.
1. On the bottom left corner: a small connector with red, black and white wires.
2. One thick white wire that attaches on the right side of the previous connector.
3. On the top edge of bOb’s motherboard: a wide multicoloured connector.
Place the cover aside and begin your repair.
Bobsweep Standard has a circular screen that is held onto the cover by five screws. Remove these to lift all pieces of the screen out. They are
LCD screen
An infrared sensor on top of the screen which will easily pop out after removal
Three springs
Silver cover plate for bOb’s buttons.
Once you’ve removed all the pieces, you can replace them in the following order:
The Infrared sensor should go in with the black side on bOb’s outside.
The button cover goes into the space on the cover.
Then the three springs sit on top of the cover, on the spring holders between the plus signs.
Finally the LCD display goes on top of the springs, facing down. Make sure to line up the holes in the screen with the screw posts on bOb’s cover.
Install all 5 screws to hold the screen and Infrared sensor in place.
To complete your repair, follow the Closing bObsweep's cover after repair
To reassemble your device, follow the guide for closing bObsweep Standard or Pethair. Closing bObsweep's cover after repair
