주요 콘텐츠로 건너뛰기
Replacing flash memory to a cisco 837 series router
필요한 것
  1. Replacing flash memory to a cisco 837 series router, Flash memory: 1 단계, 이미지 1/1
    • CISCO 837 Router
    • CISCO 877 Router
결론
CONCLUSION
Replacing flash need a tftp server available;
Replacing flash need a copy of the IOS image;
Replacing flash need the usage of ROMMON; be sure that this is possible;
Removing the flash card and inserting it back is like replacing with a new one (IOS image will be gone, so don’t play it with ease);
use the first ethernet port to connect with the tftp server, although all 4 switch ports will work presumably because all being in the same first VLAN.
To reassemble your device, follow these instructions in reverse order and that's all.
다른 한 분이 해당 안내서를 완성하였습니다.
Eneider Colina
회원 가입일: 09/20/13
2,362 평판
안내서 9개 작성하였습니다
Comunidad para traductores de español Comunidad para traductores de español 회원
Community
24 회원들
안내서 246개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 18
전체 시간: 1,258
