주요 콘텐츠로 건너뛰기
Replacing the Macintosh PowerBook 1400c Monitor
필요한 것
  1. Replacing the Macintosh PowerBook 1400c Monitor, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Replacing the Macintosh PowerBook 1400c Monitor: 2 단계, 이미지 1개 중 1개
    • Slide the latch to the left to release the battery.
  3. Replacing the Macintosh PowerBook 1400c Monitor: 3 단계, 이미지 1개 중 1개
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Replacing the Macintosh PowerBook 1400c Monitor, CD-ROM Drive: 4 단계, 이미지 1개 중 1개
    • Locate the CD-ROM Drive latch.
  5. Replacing the Macintosh PowerBook 1400c Monitor: 5 단계, 이미지 1개 중 1개
    • Slide the latch to the right to release the CD ROM drive.
  6. Replacing the Macintosh PowerBook 1400c Monitor: 6 단계, 이미지 1개 중 1개
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Replacing the Macintosh PowerBook 1400c Monitor, Keyboard: 7 단계, 이미지 1개 중 1개
    • Locate the speaker cover.
  8. Replacing the Macintosh PowerBook 1400c Monitor: 8 단계, 이미지 1개 중 1개
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Replacing the Macintosh PowerBook 1400c Monitor: 9 단계, 이미지 1개 중 1개
    • Gently lift the speaker cover to remove it.
  10. Replacing the Macintosh PowerBook 1400c Monitor: 10 단계, 이미지 1개 중 1개
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Replacing the Macintosh PowerBook 1400c Monitor: 11 단계, 이미지 1개 중 1개
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Replacing the Macintosh PowerBook 1400c Monitor: 12 단계, 이미지 1개 중 1개
    • Tilt the keyboard away from the screen.
  13. Replacing the Macintosh PowerBook 1400c Monitor: 13 단계, 이미지 1개 중 1개
    • Locate the six screws that secure the heatsink.
  14. Replacing the Macintosh PowerBook 1400c Monitor: 14 단계, 이미지 1개 중 1개
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Replacing the Macintosh PowerBook 1400c Monitor: 15 단계, 이미지 1개 중 1개
    • Lift the heatsink from the side closest to the laptop screen.
  16. Replacing the Macintosh PowerBook 1400c Monitor: 16 단계, 이미지 1개 중 1개
    • Remove the heatsink.
  17. Replacing the Macintosh PowerBook 1400c Monitor: 17 단계, 이미지 1개 중 1개
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Replacing the Macintosh PowerBook 1400c Monitor: 18 단계, 이미지 1개 중 1개
    • Detach the ribbon cable.
  19. Replacing the Macintosh PowerBook 1400c Monitor: 19 단계, 이미지 1개 중 1개
    • Remove the keyboard.
  20. Replacing the Macintosh PowerBook 1400c Monitor, Monitor: 20 단계, 이미지 1개 중 1개
    • Identify the right and left monitor end caps.
  21. Replacing the Macintosh PowerBook 1400c Monitor: 21 단계, 이미지 1개 중 1개
    • Pry off the end caps by putting a spudger between the monitor hinge and the end cap and prying outwards.
  22. Replacing the Macintosh PowerBook 1400c Monitor: 22 단계, 이미지 1개 중 1개
    • Once the end cap has been loosened by the spudger, pull outwards on the end caps.
  23. Replacing the Macintosh PowerBook 1400c Monitor: 23 단계, 이미지 1개 중 1개
    • Completely remove both end caps.
  24. Replacing the Macintosh PowerBook 1400c Monitor: 24 단계, 이미지 1개 중 1개
    • Identify the 4 total screw under the end caps (2 under each end cap).
    • The two outside 16mm long screws
    • The two inside 5.4mm long screws
  25. Replacing the Macintosh PowerBook 1400c Monitor: 25 단계, 이미지 1개 중 1개
    • Lay the monitor all the way back.
  26. Replacing the Macintosh PowerBook 1400c Monitor: 26 단계, 이미지 1개 중 1개
    • Remove the 4 screws using the Phillips #0 screwdriver.
  27. Replacing the Macintosh PowerBook 1400c Monitor: 27 단계, 이미지 1개 중 1개
    • Identify the center cap of the monitor.
  28. Replacing the Macintosh PowerBook 1400c Monitor: 28 단계, 이미지 1개 중 1개
    • Pry the center cap off by placing the spudger between the hinge and the center cap and prying upwards.
  29. Replacing the Macintosh PowerBook 1400c Monitor: 29 단계, 이미지 1개 중 1개
    • Detach the center cap completely.
  30. Replacing the Macintosh PowerBook 1400c Monitor: 30 단계, 이미지 1개 중 1개
    • Identify the one 12.6mm long screw under the center cap.
  31. Replacing the Macintosh PowerBook 1400c Monitor: 31 단계, 이미지 1개 중 1개
    • Remove the center screw with a Phillips #0 screwdriver.
  32. Replacing the Macintosh PowerBook 1400c Monitor: 32 단계, 이미지 1개 중 1개
    • Lift upwards on the metal cover under the screw.
  33. Replacing the Macintosh PowerBook 1400c Monitor: 33 단계, 이미지 1개 중 1개
    • Completely remove the metal cover.
  34. Replacing the Macintosh PowerBook 1400c Monitor: 34 단계, 이미지 1개 중 1개
    • Identify where the left and right monitor cords are attached to the logic board
    • The base of the left monitor cord
    • The base of the right monitor cord
  35. Replacing the Macintosh PowerBook 1400c Monitor: 35 단계, 이미지 1개 중 1개
    • To detach the left monitor cord grab the left monitor cord at the base of the cord and pull vertically up.
  36. Replacing the Macintosh PowerBook 1400c Monitor: 36 단계, 이미지 1개 중 1개
    • Completely detach the left monitor cord from the logic board.
  37. Replacing the Macintosh PowerBook 1400c Monitor: 37 단계, 이미지 1개 중 1개
    • To detach the right monitor cord grab the right monitor cord at the base of the cord and pull vertically up.
  38. Replacing the Macintosh PowerBook 1400c Monitor: 38 단계, 이미지 1개 중 1개
    • Completely detach the right monitor cord from the logic board.
  39. Replacing the Macintosh PowerBook 1400c Monitor: 39 단계, 이미지 1개 중 1개
    • Completely remove the monitor from the computer.
결론
Once the monitor has been removed, to attach the new monitor follow these instructions in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Taylor Chris
회원 가입일: 04/01/11
214 평판
안내서 1개를 작성함
Cal Poly, Team 10-39, Forte Spring 2011 Cal Poly, Team 10-39, Forte Spring 2011 회원
CPSU-FORTE-S11S10G39
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 28
전체 시간: 4,749
