이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the device upside down and then locate the battery latch near the front of the device.
Continue holding the latch then gently pull the battery out of the device.
Continue holding the latch then gently pull the CD-ROM Drive out of the device.
Press firmly on each end of the speaker cover and slide it to the left.
Remove the six screws from the heatsink using the Philips #1 screwdriver.
Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
Pry off the end caps by putting a spudger between the monitor hinge and the end cap and prying outwards.
Once the end cap has been loosened by the spudger, pull outwards on the end caps.
Identify the 4 total screw under the end caps (2 under each end cap).
The two outside 16mm long screws
The two inside 5.4mm long screws
Pry the center cap off by placing the spudger between the hinge and the center cap and prying upwards.
Identify where the left and right monitor cords are attached to the logic board
The base of the left monitor cord
The base of the right monitor cord
To detach the left monitor cord grab the left monitor cord at the base of the cord and pull vertically up.
To detach the right monitor cord grab the right monitor cord at the base of the cord and pull vertically up.
다른 5명이 해당 안내서를 완성하였습니다.
