주요 콘텐츠로 건너뛰기
Replacing the Metal Plate Holding the Leg of an Ironing Board
필요한 것
  1. Replacing the Metal Plate Holding the Leg of an Ironing Board, Metal plate holding the leg of the ironing board: 1 단계, 이미지 1/1
    • Place the ironing board face down on a flat, stable surface.
  2. Replacing the Metal Plate Holding the Leg of an Ironing Board: 2 단계, 이미지 1/1
    • Unscrew and remove the broken metal plate.
  3. Replacing the Metal Plate Holding the Leg of an Ironing Board: 3 단계, 이미지 1/1
    • Cut the metal sheet into an appropriate size.
    • Use cut proof gloves for protection
  4. Replacing the Metal Plate Holding the Leg of an Ironing Board: 4 단계, 이미지 1/1
    • Using a 1/8" drill bit, drill four holes on each corner where the screws will be placed.
  5. Replacing the Metal Plate Holding the Leg of an Ironing Board: 5 단계, 이미지 1/1
    • On the corner of a flat edge, use a mallet to shape the metal sheet.
    • Keep your hand at a distance from the mallet to avoid hitting your fingers.
  6. Replacing the Metal Plate Holding the Leg of an Ironing Board: 6 단계, 이미지 1/1
    • Using a screwdriver, screw on the new plate with the #10-32 x 3/8" pan-headed screws.
  7. Replacing the Metal Plate Holding the Leg of an Ironing Board: 7 단계, 이미지 1/2 Replacing the Metal Plate Holding the Leg of an Ironing Board: 7 단계, 이미지 2/2
    • Finish repairing the iron board!
결론
다른 5명이 해당 안내서를 완성하였습니다.
Nina Youn
회원 가입일: 10/26/18
211 평판
안내서 1개 작성함
UC Davis, Team S2-G1, Bender Fall 2018 UC Davis, Team S2-G1, Bender Fall 2018 회원
UCD-BENDER-F18S2G1
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 30
전체 시간: 3,003
