주요 콘텐츠로 건너뛰기
Replacing the Slider on a Coil Zipper
필요한 것
동영상 개요
  1. Replacing the Slider on a Coil Zipper, Coil Zipper Slider: 1 단계, 이미지 1/3 Replacing the Slider on a Coil Zipper, Coil Zipper Slider: 1 단계, 이미지 2/3 Replacing the Slider on a Coil Zipper, Coil Zipper Slider: 1 단계, 이미지 3/3
    • Locate the top of the zipper on the side with the slider.
    • Peel back any fabric that is covering the zipper stop.
  2. Replacing the Slider on a Coil Zipper: 2 단계, 이미지 1/2 Replacing the Slider on a Coil Zipper: 2 단계, 이미지 2/2
    • Use end nippers to cut the stop.
    • Be sure to only cut the plastic or metal stop. You do not want to damage the webbing behind the zipper.
  3. Replacing the Slider on a Coil Zipper: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Carefully remove any remaining pieces of the stop using tweezers.
  4. Replacing the Slider on a Coil Zipper: 4 단계, 이미지 1/3 Replacing the Slider on a Coil Zipper: 4 단계, 이미지 2/3 Replacing the Slider on a Coil Zipper: 4 단계, 이미지 3/3
    • Slide the damaged zipper slider up and off of the zipper.
  5. Replacing the Slider on a Coil Zipper: 5 단계, 이미지 1/2 Replacing the Slider on a Coil Zipper: 5 단계, 이미지 2/2
    • Slide the replacement slider onto the zipper.
    • You may need to tug a little to get it past where the old stop was.
    • Make sure that your zipper slider is facing the correct way (right-side up) when you place it onto the zipper.
  6. Replacing the Slider on a Coil Zipper: 6 단계, 이미지 1/2 Replacing the Slider on a Coil Zipper: 6 단계, 이미지 2/2
    • Grab a new zipper stop.
    • Insert the teeth into the webbing in the same place where the old stop was located.
  7. Replacing the Slider on a Coil Zipper: 7 단계, 이미지 1/3 Replacing the Slider on a Coil Zipper: 7 단계, 이미지 2/3 Replacing the Slider on a Coil Zipper: 7 단계, 이미지 3/3
    • Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing.
    • Crimp the stop into place.
결승점
다른 19명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,113 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 11개
Where do I get the zipper stop????
Jason Heimink - 답글
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - 답글
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - 답글
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - 답글
Great now how ! thank’s :)
Robert Fyfe - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 110
30일 전: 519
전체 시간: 99,985
