소개
You can follow this tutorial to replace the lithium-ion battery of your story factoru machine. A normal lithium-ion battery only lasts a couple of years before it starts to degrade and lose its capacity. If your Lunii doesn’t hold a charge or turns off unexpectedly, follow these instructions to recover its full abilities.
Before dismantling your Lunii, make sure to discharge the battery below 25%. A battery that has been accidentally pierced could catch fire and/or explode.
If your battery is swollen, take the necessary precautions. A swollen battery can be dangerous, so wear safety goggles and be extremely careful. Talk to a professional if you are unsure of what to do.
The original battery is a 3.7V 600mAh Li-ion battery. It is possible to use a battery with a different capacity, as long as it is also a 3.7V Li-ion battery. A lower capacity than 600mAh is not recommended because it will require more frequent recharges. A higher capacity is possible within reason, to allow for even less need to recharge. However, be careful about the dimensions, as there is limited space inside the Lunii. The dimensions of the original battery are 40mm x 30mm x 5.5mm.
필요한 것
Separate the two parts of the box, taking care to open the box well from the top, so that you end up with the contents of the box still in place in each of the halves.
Replace the battery with a new one of the same voltage (Volts). The capacity (mAh) can be the same (ideal), or higher (charging will take longer but last longer) or lower (charging will take faster but last less time).
To reassemble your device, follow these same instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 14개
Bonsoir Benoit74,
Merci pour ce mini tutoriel.
Je compte changer la batterie de la Lunii familiale, mais je rencontre quelques difficultés pour trouver une batterie Li-ion qui ressemble vaguement à celle d'origine. Toutes les batteries qui ont l'air de faire l'affaire sont des Li-Po. Est-ce en fait la même chose, mais sous différents noms ? D'un côté, je trouve des sites qui expliquent que ce sont deux choses bien différents ; de l'autre je trouve la page wikipedia qui dit que les LiPo devraient plutôt s'appeler lithium-ion polymer...
Peux-tu m'aider ?
Bonjour,
On la trouve par exemple sur AliExpress assez facilement : https://fr.aliexpress.com/item/100500133...
Concernant Li-Po vs Li-Ion, ce ne sont effectivement pas les même batteries ; je ne sais pas si le contrôleur de charge de la Lunii 2 est capable de gérer correctement les deux types de batteries. Concernant le fait que les gens disent que la Li-Po devrait s'appeller Li-Ion Po, ce qu'il veulent dire c'est que les Li-Po restent une sorte de batterie Li-Ion très spécifique.
Merci beaucoup pour ces explications qui viennent à bout d'une partie de ma confusion !
Bonjour Benoit,
L'exemple sur AliExpress ne comporte pas de Pin de connexion / de prise... Les fils sont nus. J'ai trouvé un modèle avec PIN : https://www.ebay.fr/itm/234311520496 connais-tu le modèle de connecteur ?
Belle journée,
David
David -
Bonjour,
Merci pour ce tuto 👍🏻
Peut-on mettre une batterie supérieure à 600mha ?
