주요 콘텐츠로 건너뛰기
Replacing the thermal paste on a graphics card
필요한 것
  1. Replacing the thermal paste on a graphics card, Exterior view: 1 단계, 이미지 1개 중 1개
    • In this accessible tutorial, I will show you how to replace the thermal paste on a graphics card. The method applies to all cards.
  2. Replacing the thermal paste on a graphics card, Remove the screws securing the heatsink-fan assembly: 2 단계, 이미지 2개 중 1개 Replacing the thermal paste on a graphics card, Remove the screws securing the heatsink-fan assembly: 2 단계, 이미지 2개 중 2개
    • You will have to remove the Phillips screws to detach the heat sink and the fan from the card. Some cards may be equipped with a shroud, but there isn't one on this one.
    • The screws to be removed (Red Circles)
    • I also advise to unscrew the screws in an "X" pattern (a turn or two at a time for each) so that the force exerted by the screws is very uniform and does not damage the card.
  3. Replacing the thermal paste on a graphics card, Disassembly of the heatsink/fan assembly: 3 단계, 이미지 3개 중 1개 Replacing the thermal paste on a graphics card, Disassembly of the heatsink/fan assembly: 3 단계, 이미지 3개 중 2개 Replacing the thermal paste on a graphics card, Disassembly of the heatsink/fan assembly: 3 단계, 이미지 3개 중 3개
    • It is important to remove the fan leads with care not to damage them. Disconnecting them can be tricky.
    • Graphics processor (GPU) in my case, it's a Radeon HD 7790
    • Video memory chips (VRAM) in GDDR5, on this card we have a total of 1gb of memory spread over 4 256 MB chips.
    • 6-pin 12v connector for power supply.
    • The voltage regulator modules (VRM) permit the delivery and regulate the power supplied to the GPU, VRAM etc ...
    • Connectors for video and audio such as HDMI, DVI and Display Port.
    • VRAM dedicated thermal pads.
    • Heat sink to dissipate the heat generated by the GPU VRM's and VRAM.
  4. Replacing the thermal paste on a graphics card, Replacing the thermal paste: 4 단계, 이미지 3개 중 1개 Replacing the thermal paste on a graphics card, Replacing the thermal paste: 4 단계, 이미지 3개 중 2개 Replacing the thermal paste on a graphics card, Replacing the thermal paste: 4 단계, 이미지 3개 중 3개
    • Remove the old thermal paste with a cotton swab and isopropyl alcohol. Then, apply a new dose of thermal paste (it's inexpensive).
    • After replacing the heat sink on the GPU, the thermal paste will spread.
    • Be careful not to use too much or too little paste. To be sure of the amount, you can spread it out with a card.
결론
To reassemble your device, follow the instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Shibe
회원 가입일: 05/21/22
157 평판
안내서 1개를 작성함
2가이드 댓글
Do i have to replace the thermal pads too?
Mateusz - 답글
I'm sorry, i was a bit busy, but if the thermal pads are still intact and making contact with the chip and heatsink, you can keep them.
Shibe -
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 96
지난 30일: 376
전체 시간: 4,729
