소개
Replacing the filter of the ResMed VPAP Auto 25 can result in the device running smoother and operating better. The filter can be damaged from water exposure or dust build-up. Replacing the filter is a simple task that can make a major difference.
Orient the device with the panel facing up.
Rotate device toward you so that the front panel is facing you.
Take off the translucent blue plastic cover from the top left corner of the device.
거의 끝나갑니다!
결론
