주요 콘텐츠로 건너뛰기
Resetting Windows 10
  1. Resetting Windows 10, Open settings: 1 단계, 이미지 1/2 Resetting Windows 10, Open settings: 1 단계, 이미지 2/2
    • Press Windows + I to open your settings window.
    • Then click "Update & security"
  2. Resetting Windows 10, Recovery: 2 단계, 이미지 1/1
    • From the settings window click "Recovery"
  3. Resetting Windows 10, Reset: 3 단계, 이미지 1/1
    • From the recovery menu click "Get started" under "Reset this PC"
  4. Resetting Windows 10, Keep or Remove your files: 4 단계, 이미지 1/1
    • You are then asked to choose one of two options. Pick one that would best suit your needs.
    • Keep my Files: This will keep any files you have stored in the windows Documents, Pictures and Videos folders etc. This will result in a fresh install of windows but keep all your files.
    • Remove everything: This will completely refresh the windows OS, free from any files or apps that where on before, any files stored on other drives or partitions will remain. Make sure you back up any data you want to keep before choosing this option.
  5. Resetting Windows 10, A few more clicks: 5 단계, 이미지 1/3 Resetting Windows 10, A few more clicks: 5 단계, 이미지 2/3 Resetting Windows 10, A few more clicks: 5 단계, 이미지 3/3
    • After a short wait, windows will let you know what apps will be uninstalled. Click "Next"
    • After reading a quick overview of what is about to happen. Click "Reset"
  6. Resetting Windows 10, Lots of loading: 6 단계, 이미지 1/3 Resetting Windows 10, Lots of loading: 6 단계, 이미지 2/3 Resetting Windows 10, Lots of loading: 6 단계, 이미지 3/3
    • The rest is automatic and will take some time. Make yourself a cup of tea and relax.
  7. Resetting Windows 10, Finishing touches: 7 단계, 이미지 1/3 Resetting Windows 10, Finishing touches: 7 단계, 이미지 2/3 Resetting Windows 10, Finishing touches: 7 단계, 이미지 3/3
    • Once the reset is finished just log in as normal.
    • Windows will make a few final changes, and your done!
    • On your desktop will be a html file that will contain all the apps that were removed.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Conor Bailey
회원 가입일: 04/27/16
7,968 평판
안내서 2개 작성하였습니다
Tech Haus Tech Haus 회원
Business
1 회원
안내서 12개 작성하였습니다
댓글 2개
Really nice information to the techies and readers... who want to do the job yourself.. I m sure anyone can reset the laptop , if he she follows the instructions mentioned here.
ncrsystemsolution - 답글
what if you forgot your password and you won’t open it. you want to reset your laptop what should i do?
John Paul - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 18
전체 시간: 3,583
