주요 콘텐츠로 건너뛰기
Respironics REMstar Plus M Series Power Supply Circuit board Replacement
필요한 것
  1. Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: 1 단계, 이미지 1/3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: 1 단계, 이미지 2/3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: 1 단계, 이미지 3/3
    • Place the device face down.
    • Use a T15 Torx screwdriver to remove the six screws in the base plate.
    • Lift the base plate off of the device.
  2. Respironics REMstar Plus M Series Power Supply Circuit board Replacement: 2 단계, 이미지 1/3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: 2 단계, 이미지 2/3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: 2 단계, 이미지 3/3
    • Flip the circuit board over to the right.
    • Gently pull the ribbon cable outward to disconnect it from the circuit board.
  3. Respironics REMstar Plus M Series Power Supply Circuit board Replacement: 3 단계, 이미지 1/2 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: 3 단계, 이미지 2/2
    • Disconnect the red 3-wire plug at the top left of the board and the white 4-wire plug at the bottom left.
    • Remove the circuit board.
결론
Brent Forrest
회원 가입일: 09/17/20
173 평판
안내서 2개 작성하였습니다
댓글 2개
My unit stops working in the middle of the night, then beeps, & blue light flashes. Will replacing this board fix this, and where can I get one?
mert454 - 답글
Where to find a power supply circuit board for my Remstar plus m series which just blinks blue lights. dledes@shaw.ca
David Edes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 994
