주요 콘텐츠로 건너뛰기
Restoring Cast Iron Cookware
필요한 것
  1. Restoring Cast Iron Cookware, Restoring Cast Iron Cookware: 1 단계, 이미지 2개 중 1개 Restoring Cast Iron Cookware, Restoring Cast Iron Cookware: 1 단계, 이미지 2개 중 2개
    • Identify rust spots on the cast iron pan or skillet.
    • If there is noticeable rust, continue to step 2. If there is not, and the pan or skillet merely needs to be re-seasoned, then skip to step 4.
  2. Restoring Cast Iron Cookware: 2 단계, 이미지 2개 중 1개 Restoring Cast Iron Cookware: 2 단계, 이미지 2개 중 2개
    • Prepare the vinegar soak by combining vinegar and water in equal parts to fill a large tub.
    • The tub or basin used should be large enough to completely submerge the desired piece of cookware.
    • The soak should be roughly a 1:1 ratio between white vinegar and water.
    • The ratio does not need to be exact; close enough is good enough.
  3. Restoring Cast Iron Cookware: 3 단계, 이미지 1개 중 1개
    • Let the pan or skillet soak for roughly 30 minutes or until the rust begins to flake off.
    • An easy way to check if the pan is ready is to scratch lightly at the rust with a fingernail. If it flakes off immediately, remove the pan from the soak.
  4. Restoring Cast Iron Cookware: 4 단계, 이미지 3개 중 1개 Restoring Cast Iron Cookware: 4 단계, 이미지 3개 중 2개 Restoring Cast Iron Cookware: 4 단계, 이미지 3개 중 3개
    • Thoroughly rinse and refill the tub with water. A kitchen sink can be used for this step instead.
    • Thoroughly rinse the pan or skillet, then scrub it with steel wool and dish soap.
    • Continue to scrub until there is no remaining rust.
  5. Restoring Cast Iron Cookware: 5 단계, 이미지 1개 중 1개
    • It is important to note that the seasoning has now been completely removed along with the rust. This is not a problem as re-seasoning will be covered in the next step.
    • Dry the pan or skillet thoroughly. No moisture can remain when continuing onto the next step.
    • Optionally, the pan can be placed into an oven set to warm to dry it both quickly and thoroughly.
  6. Restoring Cast Iron Cookware: 6 단계, 이미지 3개 중 1개 Restoring Cast Iron Cookware: 6 단계, 이미지 3개 중 2개 Restoring Cast Iron Cookware: 6 단계, 이미지 3개 중 3개
    • Coat the pan or skillet with vegetable oil.
    • Spread the oil evenly across the surface of the pan.
    • The coating should be kept relatively thin, so do not be afraid to dab up excess oil with a paper towel.
  7. Restoring Cast Iron Cookware: 7 단계, 이미지 2개 중 1개 Restoring Cast Iron Cookware: 7 단계, 이미지 2개 중 2개
    • Spread aluminum foil on the bottom rack of the oven you intend to use.
    • This is to catch any drips from the oil coated pan.
  8. Restoring Cast Iron Cookware: 8 단계, 이미지 1개 중 1개
    • Pre-Heat the oven to 350 degrees Fahrenheit .
  9. Restoring Cast Iron Cookware: 9 단계, 이미지 1개 중 1개
    • Place the oil coated pan or skillet face down onto the top rack of the oven.
    • Allow the pan or skillet to bake for 1 hour at 350 degrees Fahrenheit.
    • Once the hour is up, turn off the oven, but do not remove the pan yet. Allow the pan to cool down with the oven over the next 45 minutes.
  10. Restoring Cast Iron Cookware: 10 단계, 이미지 3개 중 1개 Restoring Cast Iron Cookware: 10 단계, 이미지 3개 중 2개 Restoring Cast Iron Cookware: 10 단계, 이미지 3개 중 3개
    • Remove the pan from the oven. Then apply a final, and extremely light, coating of vegetable oil to help smooth over any irregularities.
    • If the pan is still hot, use oven mitts to remove it. Burns hurt.
결론
The skillet is now completely restored, good as new. For the best results, reapply the last thin coat of vegetable oil after the next few uses of the cast iron pan or skillet.
다른 15명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Spencer Dahler
회원 가입일: 10/04/16
688 평판
안내서 1개를 작성함
6가이드 댓글
The ceramic coating eventually gets chipped, exposes the CI. CI is not dangerous except in the hands of a mad house wife.
lks - 답글
Very good friend.
Miguel -
This to restore a Cast Iron that has not maintained. This has nothing to cleaning regularly.
For regularly clean I put water in it and heat to a boil, dump, and whip. I’m done.
Rodney Moore - 답글
I prefer ENAMEL ( https://en.wikipedia.org/wiki/Industrial... ) coated iron cookware
MEX - 답글
Thanks for the step-by step. This is helpful. I love cooking on cast iron. I also have an old set that has not been maintained well. I switched to ceramic cookware https://ceramiccookwarereview.com/. However once ceramic goes, it is trash. I’m going to give your method a go and will let you know how it goes. Thanks again.
Ron - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 36
지난 30일: 151
전체 시간: 18,260
