이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Cast iron pans and skillets are a joy to cook with, but maintaining them can be demanding and a failure to do so can lead to rusted and ruined cookware. Fortunately, cast iron is resilient and removing that rust is actually quite easy. The main trick to restoring any piece of cast iron cookware is actually properly re-seasoning it. Though there are many methods to accomplish this, our guide aims to present the process with the best blend of cost effectiveness and safety.
필요한 것
Identify rust spots on the cast iron pan or skillet
If there is noticeable rust, continue to step 2. If there is not, and the pan or skillet merely needs to be re-seasoned, then skip to step 4.
The skillet is now completely restored, good as new. For the best results, reapply the last thin coat of vegetable oil after the next few uses of the cast iron pan or skillet.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 6개
This to restore a Cast Iron that has not maintained. This has nothing to cleaning regularly.
For regularly clean I put water in it and heat to a boil, dump, and whip. I’m done.
I prefer ENAMEL ( https://en.wikipedia.org/wiki/Industrial... ) coated iron cookware
Thanks for the step-by step. This is helpful. I love cooking on cast iron. I also have an old set that has not been maintained well. I switched to ceramic cookware https://ceramiccookwarereview.com/. However once ceramic goes, it is trash. I’m going to give your method a go and will let you know how it goes. Thanks again.
