이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Prepare the vinegar soak by combining vinegar and water in equal parts to fill a large tub.
Let the pan or skillet soak for roughly 30 minutes or until the rust begins to flake off.
Thoroughly rinse the pan or skillet, then scrub it with steel wool and dish soap.
Continue to scrub until there is no remaining rust.
Dry the pan or skillet thoroughly. No moisture can remain when continuing onto the next step.
Optionally, the pan can be placed into an oven set to warm to dry it both quickly and thoroughly.
Coat the pan or skillet with vegetable oil.
Spread the oil evenly across the surface of the pan.
Place the oil coated pan or skillet face down onto the top rack of the oven.
Allow the pan or skillet to bake for 1 hour at 350 degrees Fahrenheit.
Once the hour is up, turn off the oven, but do not remove the pan yet. Allow the pan to cool down with the oven over the next 45 minutes.
Remove the pan from the oven. Then apply a final, and extremely light, coating of vegetable oil to help smooth over any irregularities.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 6개
This to restore a Cast Iron that has not maintained. This has nothing to cleaning regularly.
For regularly clean I put water in it and heat to a boil, dump, and whip. I’m done.
I prefer ENAMEL ( https://en.wikipedia.org/wiki/Industrial... ) coated iron cookware
Thanks for the step-by step. This is helpful. I love cooking on cast iron. I also have an old set that has not been maintained well. I switched to ceramic cookware https://ceramiccookwarereview.com/. However once ceramic goes, it is trash. I’m going to give your method a go and will let you know how it goes. Thanks again.
