소개
Use this guide to replace the complete Retina Display assembly on your Retina MacBook 2015.
To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable. These accessories are not included with your MacBook, so make sure you have them ready before you begin.
도구
동영상 개요
Remove the following eight screws securing the lower case:
Two 1.8 mm P5 Pentalobe screws
Four 2.9 mm P5 Pentalobe screws
Two 6.1 mm P5 Pentalobe screws
Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
Wow okay could someone explain why this is necessary? What happens if you skip this step and simply undo the screw to disconnect the power?
Removing the screw does not disconnect the power—power comes from the battery terminals contacting the underside of the logic board, and they’re tricky to separate reliably at this stage of disassembly. This step is the safest and easiest way to kill power; don’t skip it.
Lifting from the front edge, open the lower case to an angle of about 45°.
Before the IPD flex cable can be removed the battery disconnect button has be held down for up to 10 seconds. If the LED near the battery connector is switched on it shows that there is power going through the logic board from the battery, once the button is pressed and this light goes off the machine is safe to be worked on.
Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
This is very tricky indeed - at least on my computer. I failed at this point - having skipped to it as sugested above so as not to stress the ribbons on the other side. The ZIF was not as I expected. They had opened when I pulled up the stick cover and I found I was working on the socket itself. The top edge came adrift after almost no pressure being put on it. The ribon did not come free with gentle pulling though. At that point I put the back on again… waited until the battery recharged a bit and found I had not nroken it after all. I doubt I shall try again. It is much harder to replace than the 15 inch - much…
I’ve just found that I have broken it after all. No keyboard. Bluetooth still works so I can use the machine.
All in all, an expensive mistake. BTW - I did NOT get the kit from IFIXIT - not sold here.
I found “Recognizing & Disconnecting Cable Connectors”
useful, esp. for someone who has not used ZIF connectors and retaining flaps before. There are several retaining flaps that need to be opened. The first time is tricky as you need a sense of how much force to apply. I used the flat end of the provided spudger. Apply progressively firmer upward pressure until the retaining flap pops open. The first time is tricky, but straightforward thereafter.
Carefully turn the MacBook over, so that the lower case lays flat.
Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
You can open the laptop screen all the way open with it flat in the table (screen facing up) and the keyboard should stay up.
Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
the moment you opening macbook case and before any tinkering with connections, you MUST press little yellow button on logicboard, located on the right from battery connector - this will disable all power to the board. You can check by looking at the small led on left side of the battery connector - if there is very faint light, it means that power is still there. After pressing button light should go off. Removing screw is not necessary at all, and like I said - you MUST disable power before any touching to connections etc.
As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
Remove the two screws securing the USB-C port cable bracket:
1.1 mm Tri-point Y00 screw
3.5 mm T5 Torx screw
On the 2016 model the tri-point Y00 is actually a Phillips screw, so need of that special tool.
The 2015 model has the Phillips—PH000
-jay
Confirmation as well, 2015 model does not have a tri-tip, but actually a Phillips head.
I should have read the comments before using the provided 1.1 mm Tri-point Y00 bit. I almost stripped the screw but was able to use a small flat head bit to open the screw.
Ifixit: you may want to update this part in the instructions. Not everyone reads the comment section, esp. when it comes to specification of bits which is basic and must be accurate. This is one of the more critical ones in the procedure that can easily go south. The rest of the instructions are excellent.
early 2015 model here. I’ve used a Y1.5 with cautiously applied down force.
My 2015 had a 2.5mm Y screw not a Y000.
Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
Emphasis on aligning the bracket correctly. What the pictures do not show is that underneath the flat part of the metal bracket (the area between the two screw holes) is a connector that needs to be accurately aligned. Aligning the two screw holes does not imply that the connector is seated correctly.
After I re-assembled my 2015 MacBook power would not come on. I thought I had damaged the logic board despite being careful and following instructions. Diagnosing the problem took a while. Retracing the steps and focusing on power supply I was able to determine that the metal flap which hides the connector underneath had not made proper contact.
What I did was to use a finger to get a tactile feel for the connector underneath the metal bracket aligning properly and then press down vertically when it seemed to be aligned. It’s a subtle tactile feel. After re-doing this step, I got power back. Be careful not to damage the connector as noted in the instructions.
Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
Use tweezers to peel back the tape covering the display cable connector.
Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
Disconnect the display cable by gently pulling it straight out of its connector.
A step was skipped. You have to flip up the metal locking tab on the socket before the cable can be removed. See the photo.
And be careful when re-inserting the connector. One end of the two indentations got a little bent (I did not notice) which resulted in a black screen when powering up. I used a heat gun (low setting) to separate the cable from the labtop housing. When re-assembling, first insert the connector (after closing the metal flap as instructed), verify that it’s properly seated, then re-attach the rest of the cable to the laptop housing. In the first try, I first re-attached the cable to the housing, then tried to insert the cable connected into the metal socket. Because of a lack of slack, the cable connector at one end got bent slightly. After identifying the problem, I had to straighten it/unbend out using my fingers. Hence it is easier to insert the connector first, then attach the rest of the cable to the laptop housing.
Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
Does unplugging the "dual microphone assembly ribbon cable" affect anything other than the microphones? The headphone jack is separate, for example, right?
Right. We haven't tested it, but unplugging that cable shouldn't affect anything other than the microphones. You can see the microphone assembly in this guide.
Use tweezers to pull the microphone assembly ribbon cable free of its connector.
I broke the microphone assembly ribbon cable, from step twenty five. Is there anyway to fix this, soldering kit, or can I order a new cable online?
Remove the four 4.8 mm T8 Torx screws securing the display hinges.
On an early 2015 model, I found the T9 Torx bit to be too tight a fit in the hinge screw heads. Almost to the point where one screw head got slightly damaged as the bit slipped when turning as it hadn’t gone in far enough. This is the T9 bit that came with the iFixIt 64 bit driver kit.
So I used the T8 bit instead and managed to loosen the other screws much more easily. It’s a slightly looser fit but it goes in further and didn’t slip even though the screws on this particular machine were very very tightly screwed in.
@cool_breeze I think you’re right and this is probably a mistake in the guide. Apple commonly uses T8 screws, T9 not so much. But it can be hard to tell for sure depending on which toolkit you happen to be using. I’ll update the text to say T8! Thanks for the heads-up.
Holding the display assembly with one hand and the upper case with the other, push them together slightly to move the hinges out of their recesses in the the upper case.
Push the upper case forward while pulling back gently on the display.
Once the two display hinges have cleared the upper case, remove the display and set it aside.
How long does it take usually before you should hear the chime? Any way to test that the USB-C has been properly plugged backed in before reassembling everything?
To reassemble your device, follow these instructions in reverse order. To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
다른 37명이 해당 안내서를 완성하였습니다.
댓글 20개
thank you: very good and clear guiding through
Is there a guide to replace the LCD without replacing the entire shell with housing? Replacements for the LCD only are alt cheaper than buying the entire thing.
MrNewbhero - 답글
MrNewbhero - You probably can replace it without a full clamshell, however, be advised that the front glass acts as a part of the LCD and the layers underneath are just backlight pieces and so on. It's a very difficult job for a DIY
This repair is so nervewreaking. I suggest everyone to take your time and really make sure you're not rushing it, or you may break the connectors, as there's tape on everything almost breaking the connector when you remove the flex cable.
My screen bezel is tearing apart in pieces and got no damage, drop or else, since day 1 I use a UrbanArmor cover, how can I change it, I bought a replacement in eBay.
Is this valid for the 2016 model? Does the 2016 model use the same display assembly replacement?
Regards
The procedure is very similar on the 2016 model, with a few minor differences (screw types, etc). Some differences are documented here, but following this guide should get you 99% of the way there. I'm not sure whether the display itself is compatible/interchangeable between model years.
Ive just done a screen replacement after my son spilled tea over it. The MacBook was still functioning, sound, booting up etc but the screen was dead. Ive just replaced the screen, all works fine, but now the trackpad and keyboard are not working/no power and the trackpad is getting very hot. Does the trackpad send power to the keyboard in this design as it seems like the only link to via a cable.
I changed the screen but now it won’t start anymore. Any ideas ?
There’s an alternate way to replace the display assembly shown in a YouTube video from a UK company. It's seemingly a lot less steps, easier, and much quicker. I followed it successfully, so I’m not sure why there is such a big difference between their procedure and this one…
jgregson00 - 답글
I think you were lucky. In that video they do not disconnect the battery, they pry apart ZIF connectors with a screwdriver, they reconnect the TCON cable incorrectly, they skip the 5W charging procedure—all good ways to brick your device. Glad it worked out for you, but I would not recommend anyone follow that example.
I did the repair and all works except the when i click the trackpad little harder the screen goes off and i press it again goes on. Is this the battery connector or any suggestions?
Hi, I did the tutorial and everything worked out except for one thing. My Macbook isn’t detecting when I close it and open it. I would like some help, does anyone know how to solve it?
Excellent guide, as always with I fix it. I always come to your site even for repairs I’m used to just for the screws refs/colors etc which are so convenient.
But now I’m not starting a repair without you since as years go by you keep adding really precious notes and info (I.e in this guide, to power the 2015 models with a phone charger first), which along with all the hi-res pictures makes you the apple products repair authority by far! THANK YOU!
excellent explained! thanks. i. hav the problem that my webcam doesn’t work anymore. I don’t understand why. i’ve tried the Sudo killall in terminal the pram the nvram resets. but he doesn’t find my webcam. does someone know what the problem/damage is? thanks!
Everything worked except that when I finished, I discovered that I had no sound and internal speakers does not appear as an option in the sound pane in System Preferences. So I assume I must have accidentally disconnected something but I am not see anything. Any clue what I missed and how to fix this?
Hi my screen had a column of about 3 cm wide that sometime come more dark than the rest of the display, near the center of the MacBook.
I saw that this column with some micro movement of the display sometime goes off. So I had assumed that the problem could be the flex cable that connect the display assembly to the logic board, it's possible or the problem is the lcd itself?
If, like me, you didn’t have a P5 Pentalope screwdriver but did have one that fits an iPhone.
You can sand down the tip until it’s the right size.
Stuart - 답글
