주요 콘텐츠로 건너뛰기
Retina MacBook 2017 Headphone Jack Replacement
필요한 것
  1. Retina MacBook 2017 Headphone Jack Replacement, Disable Auto Boot: 1 단계, 이미지 3개 중 1개 Retina MacBook 2017 Headphone Jack Replacement, Disable Auto Boot: 1 단계, 이미지 3개 중 2개 Retina MacBook 2017 Headphone Jack Replacement, Disable Auto Boot: 1 단계, 이미지 3개 중 3개
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. Retina MacBook 2017 Headphone Jack Replacement, Unfasten the lower case: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. Retina MacBook 2017 Headphone Jack Replacement: 3 단계, 이미지 3개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 3 단계, 이미지 3개 중 2개 Retina MacBook 2017 Headphone Jack Replacement: 3 단계, 이미지 3개 중 3개
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  4. Retina MacBook 2017 Headphone Jack Replacement: 4 단계, 이미지 1개 중 1개
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  5. Retina MacBook 2017 Headphone Jack Replacement: 5 단계, 이미지 2개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
  6. Retina MacBook 2017 Headphone Jack Replacement: 6 단계, 이미지 3개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 6 단계, 이미지 3개 중 2개 Retina MacBook 2017 Headphone Jack Replacement: 6 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
  7. Retina MacBook 2017 Headphone Jack Replacement: 7 단계, 이미지 1개 중 1개
    • Close the MacBook and carefully flip it upside-down.
  8. Retina MacBook 2017 Headphone Jack Replacement: 8 단계, 이미지 1개 중 1개
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
  9. Retina MacBook 2017 Headphone Jack Replacement: 9 단계, 이미지 2개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
  10. Retina MacBook 2017 Headphone Jack Replacement: 10 단계, 이미지 3개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 10 단계, 이미지 3개 중 2개 Retina MacBook 2017 Headphone Jack Replacement: 10 단계, 이미지 3개 중 3개
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
  11. Retina MacBook 2017 Headphone Jack Replacement: 11 단계, 이미지 2개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 11 단계, 이미지 2개 중 2개
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  12. Retina MacBook 2017 Headphone Jack Replacement: 12 단계, 이미지 3개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 12 단계, 이미지 3개 중 2개 Retina MacBook 2017 Headphone Jack Replacement: 12 단계, 이미지 3개 중 3개
    • Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
    • Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  13. Retina MacBook 2017 Headphone Jack Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
  14. Retina MacBook 2017 Headphone Jack Replacement: 14 단계, 이미지 2개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 14 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Battery Blocker
    $3.99
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
  15. Retina MacBook 2017 Headphone Jack Replacement, USB-C and Audio Jack Disconnect: 15 단계, 이미지 1개 중 1개
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Phillips #00 screw
    • Some variations of this model may use a Tri-point Y00 screw.
    • 3.5 mm T5 Torx screw
  16. Retina MacBook 2017 Headphone Jack Replacement: 16 단계, 이미지 2개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 16 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
  17. Retina MacBook 2017 Headphone Jack Replacement: 17 단계, 이미지 2개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 17 단계, 이미지 2개 중 2개
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  18. Retina MacBook 2017 Headphone Jack Replacement: 18 단계, 이미지 2개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 18 단계, 이미지 2개 중 2개
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so the white stripe faces you. Insert the cable until the white line disappears under the socket.
    • At this point it is possible to open the macbook all the way and to lay it flat on a table without causing any damage to the flex cables.
  19. Retina MacBook 2017 Headphone Jack Replacement, Audio Jack Board: 19 단계, 이미지 2개 중 1개 Retina MacBook 2017 Headphone Jack Replacement, Audio Jack Board: 19 단계, 이미지 2개 중 2개
    • Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
  20. Retina MacBook 2017 Headphone Jack Replacement: 20 단계, 이미지 2개 중 1개 Retina MacBook 2017 Headphone Jack Replacement: 20 단계, 이미지 2개 중 2개
    • Disconnect the microphone assembly ribbon cable by pulling it straight out of its connector.
  21. Retina MacBook 2017 Headphone Jack Replacement: 21 단계, 이미지 1개 중 1개
    • Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
  22. Retina MacBook 2017 Headphone Jack Replacement: 22 단계, 이미지 1개 중 1개
    • Remove the audio jack board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
129,331 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
1가이드 댓글
my system doesn't have volume out from the speaker, likewise, the 3.5mm jack is not working
please i need help
Otherthy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 56
지난 30일: 298
전체 시간: 7,679
