주요 콘텐츠로 건너뛰기
Retro-Bit Retro Duo Cartridge Doors Replacement
필요한 것
  1. Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: 1 단계, 이미지 3개 중 1개 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: 1 단계, 이미지 3개 중 2개 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: 1 단계, 이미지 3개 중 3개
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Remove it before the screws.
    • Flip the console on its feet, pinch near the AV/S ports, and carefully lift the top casing.
    • Do not completely remove the top casing. There is a small LED circuit board connected to the main circuit board.
  2. Retro-Bit Retro Duo Cartridge Doors Replacement: 2 단계, 이미지 3개 중 1개 Retro-Bit Retro Duo Cartridge Doors Replacement: 2 단계, 이미지 3개 중 2개 Retro-Bit Retro Duo Cartridge Doors Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case and set aside.
  3. Retro-Bit Retro Duo Cartridge Doors Replacement: 3 단계, 이미지 3개 중 1개 Retro-Bit Retro Duo Cartridge Doors Replacement: 3 단계, 이미지 3개 중 2개 Retro-Bit Retro Duo Cartridge Doors Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the eight 10 mm Phillips #0 screws.
    • The cartridge doors are spring-loaded and may pop up.
  4. Retro-Bit Retro Duo Cartridge Doors Replacement: 4 단계, 이미지 2개 중 1개 Retro-Bit Retro Duo Cartridge Doors Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully lift the cartridge door case and set aside.
  5. Retro-Bit Retro Duo Cartridge Doors Replacement: 5 단계, 이미지 2개 중 1개 Retro-Bit Retro Duo Cartridge Doors Replacement: 5 단계, 이미지 2개 중 2개
    • Take the cartridge doors out of the top casing.
    • Keep the correct cartridge doors together. Note the door numbers and position.
    • Doors numbered two and four are for NES cartridges.
    • Doors numbered three are for SNES cartridges.
결론
작성자
3다른 기여자 명과 함께
Truong Vo
회원 가입일: 09/25/17
324 평판
안내서 3개를 작성함
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G4
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 13
전체 시간: 744
