주요 콘텐츠로 건너뛰기
소개
The circuit board is essential to the console's functions. Using Phillips #0 and Phillips #2 screwdrivers, you can replace it.
부품
지정된 부품이 없습니다.
  1. With the console on its top, remove the four 12 mm Phillips #2 screws. There may be a sticker covering one or more of the screws. Simply remove the sticker before screw removal. Flip the console on its feet.  Carefully lift the top casing from the back (where the AV/S and power ports are).
    • With the console on its top, remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Simply remove the sticker before screw removal.
    • Flip the console on its feet. Carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not remove the top casing completely. There is a small LED circuit board connected to the main circuit board.
  2. Remove the one 6 mm Phillips #0 LED circuit board screw. Lift the top case and set aside. Lift the top case and set aside.
    • Remove the one 6 mm Phillips #0 LED circuit board screw.
    • Lift the top case and set aside.
  3. Remove  the 11 screws holding the circuit boards and ports in place. Six 11 mm Phillips #2 holding the circuit boards. Three 12 mm Phillips #2 screws holding the controller ports.
    • Remove the 11 screws holding the circuit boards and ports in place.
    • Six 11 mm Phillips #2 holding the circuit boards.
    • Three 12 mm Phillips #2 screws holding the controller ports.
    • Two 7 mm Philllips #2 screws holding the back ports
  4. Carefully lift the circuit board while holding either the AV or controller ports. Alternatively, you can hold the circuit board on its edges. Make sure to lift the circuit board completely out of the bottom case. To avoid damage, do not to touch the top or bottom faces of the circuit board.
    • Carefully lift the circuit board while holding either the AV or controller ports. Alternatively, you can hold the circuit board on its edges.
    • Make sure to lift the circuit board completely out of the bottom case.
    • To avoid damage, do not to touch the top or bottom faces of the circuit board.
결론
Truong Vo
회원 가입일: 2017년 09월 25일
320 평판
안내서 3개 작성하였습니다
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G4
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
I hope you show the second part were you replace the 72pin connector. Please include part source.
The 72 pin connector grabs too tightly on the cart.
Thanks.
George Tedrick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 34
전체 시간: 1,488
