주요 콘텐츠로 건너뛰기
Retro-Bit Retro Duo Circuit Board Replacement
필요한 것
  1. Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: 1 단계, 이미지 1/3 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: 1 단계, 이미지 2/3 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3/3
    • With the console on its top, remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Simply remove the sticker before screw removal.
    • Flip the console on its feet. Carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not remove the top casing completely. There is a small LED circuit board connected to the main circuit board.
  2. Retro-Bit Retro Duo Circuit Board Replacement: 2 단계, 이미지 1/3 Retro-Bit Retro Duo Circuit Board Replacement: 2 단계, 이미지 2/3 Retro-Bit Retro Duo Circuit Board Replacement: 2 단계, 이미지 3/3
    • Remove the one 6 mm Phillips #0 LED circuit board screw.
    • Lift the top case and set aside.
  3. Retro-Bit Retro Duo Circuit Board Replacement: 3 단계, 이미지 1/3 Retro-Bit Retro Duo Circuit Board Replacement: 3 단계, 이미지 2/3 Retro-Bit Retro Duo Circuit Board Replacement: 3 단계, 이미지 3/3
    • Remove the 11 screws holding the circuit boards and ports in place.
    • Six 11 mm Phillips #2 holding the circuit boards.
    • Three 12 mm Phillips #2 screws holding the controller ports.
    • Two 7 mm Philllips #2 screws holding the back ports
  4. Retro-Bit Retro Duo Circuit Board Replacement: 4 단계, 이미지 1/3 Retro-Bit Retro Duo Circuit Board Replacement: 4 단계, 이미지 2/3 Retro-Bit Retro Duo Circuit Board Replacement: 4 단계, 이미지 3/3
    • Carefully lift the circuit board while holding either the AV or controller ports. Alternatively, you can hold the circuit board on its edges.
    • Make sure to lift the circuit board completely out of the bottom case.
    • To avoid damage, do not to touch the top or bottom faces of the circuit board.
결론
Truong Vo
회원 가입일: 09/25/17
320 평판
안내서 3개 작성하였습니다
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G4
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
I hope you show the second part were you replace the 72pin connector. Please include part source.
The 72 pin connector grabs too tightly on the cart.
Thanks.
George Tedrick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 20
전체 시간: 2,344
