주요 콘텐츠로 건너뛰기
Retro-Bit Retro Duo Controller Button and Pad Replacement.
필요한 것
  1. Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): 1 단계, 이미지 1/3 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): 1 단계, 이미지 2/3 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): 1 단계, 이미지 3/3
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After screw removal, carefully lift the controller casing.
  2. Retro-Bit Retro Duo Controller Button and Pad Replacement.: 2 단계, 이미지 1/3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 2 단계, 이미지 2/3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 2 단계, 이미지 3/3
    • Pinch the top and bottom of the shoulder pads, then lift out.
    • There are small elastic pads below each shoulder pad. Replace these if they are not functioning correctly.
  3. Retro-Bit Retro Duo Controller Button and Pad Replacement.: 3 단계, 이미지 1/3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 3 단계, 이미지 2/3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 3 단계, 이미지 3/3
    • Carefully lift the circuit board from the controller case.
  4. Retro-Bit Retro Duo Controller Button and Pad Replacement.: 4 단계, 이미지 1/3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 4 단계, 이미지 2/3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 4 단계, 이미지 3/3
    • To replace the action button pad, lift this part out.
    • Lift the Select and Start button pad.
    • If replacing the D-Pad, lift this pad.
    • Pinch and lift the shoulder button pads.
  5. Retro-Bit Retro Duo Controller Button and Pad Replacement.: 5 단계, 이미지 1/3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 5 단계, 이미지 2/3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 5 단계, 이미지 3/3
    • Support the controller face and push buttons toward the inner case.
    • Use care. The buttons have a tiny tab to keep them in place.
    • Support the controller face and push the D-Pad toward the inner case.
결론
Evelyn
회원 가입일: 09/25/17
223 평판
안내서 2개 작성하였습니다
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G4
3 회원들
안내서 10개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 30
전체 시간: 933
